Digital Art Zone
Custom morph files under Shaping / Posing tab?
Posted: 03 October 2012 07:35 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2012-06-11
Does anyone know how to get custom Genesis morphs to be visible in the Shaping and/or Posing tabs when using .dsf files (I have yet to upgrade to 4.5)?
I like the option of using ERC freeze in the property editor tab, but the resulting morph and pose dials only appear under the Parameters tab regardless of what node and/or group I assign them. This isn’t an end of the world issue or anything, but it would be far more convenient to use them via the Shaping or Posing tabs.
I’ve compared .dsf files to determine what decides whether they show up as desired, but I have yet to find the smoking gun.
Profile
Posted: 04 October 2012 04:59 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I’ve not had to look into this, but try assigning a region to the morph and then look under that region in the Shaping pane.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 04 October 2012 05:33 AM   [ Ignore ]   [ # 2 ]
Active Member
RankRank
Joined  2009-12-07
Dan
Its the Content Type that determines whether they show up in the presets tabs. If you open the Content DB Editor from the Content Library menu you can assign a type to each of those assets.
The ones you’re looking for are Presets/Morph/... and Presets/Pose.
 Signature
PoseMaster for DAZ Studio and PoseMaster People Pack now sold at Rendo.
Profile
Posted: 04 October 2012 06:20 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Indeed, I’d forgotten setting the property type.
 Signature
Profile
Posted: 04 October 2012 07:43 AM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
mmm,,, I am sorry If I say mistake,,
but I think about morph dsf in data,, we seems not access by content editor.
(or is that way to save the morph which can set meta-data in content editror?)
then cridgit say right , I understand the category where you can see the morph desided by “type”
not Path eg, “Actor/Female” (it seems decide node hierarlchy and category in editor )
I think we can decide the type about morph,  by the parameter setting editor, I think,,.
eg ”Modifier/Shape” it can show your morph with erc in shape tab.
(I hope it is right, and I am mazing about types and yet grab crear knowledge too,,)
edited
afther change type, you need to save the controller settings by save modified assets ,
or simple “save as moprh” to keep the type of dsf morph file.
“Path” is important too, they seems decide the selection and node,
when use pozing tool , and region navigation.  about pozing and shaping tab,
they move with these tool.
Profile
Posted: 04 October 2012 11:35 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
Rank
Joined  2003-10-09
The type on the property should be set to:
- “Modifier/Shape” for it to show up on the Shaping pane
- “Modifier/Pose” for it to show up on the Posing pane
For a figure like Genesis, that has Regions, a property must also be assigned to a Region to show up on the Shaping pane. For figures that do not have Regions, like the previous generations, this is not a requirement.
In 4.5, this is easily done in the Parameter Settings dialog via the Path and Type attributes. The Parameter Settings dialog is accessed from the option menu that pops up when you click on the gear icon in the top right corner of a parameter.
-Rob
 Signature
- Documentation Center
- Install Manager
- DAZ Studio 4.x
- DSON Importer
- DSON File Format Specification
Profile
Posted: 04 October 2012 01:44 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2012-06-11
Thanks for the help! The issue with the .dsf files was definitely the lack of any settings for “Presentation”, and those are easily set via the Parameters tab. I was thrown by the fact that even if you don’t set presentation, you can still fine “Modifier/Shape” and such in the file. With presentation set up properly, however, that shows up twice. Once under asset info, and once under presentation.
Thanks again!
Profile
