Hi,
I’m trying to make some clothing content for Genesis.
Initially when I starting testing I was modelling the clothing around a morphed character. Thanks to the forums I quickly found that I should be modelling around the Base Female Genesis character.
Instead of modelling a whole outfit this time, I just modelled some quick pieces for testing. Unfortunately I’m still having issues.
As you can see in the pics, the clothing has been modelled to perfectly fit the Genesis Female Base. As soon as I use the Transfer Utility, it shrinks the model down. I’ve turned down the opacity of Genesis to demonstrate what’s happening.
I’ve tried importing the model with slightly larger scale and the affect is exactly the same.
The easy solution would be to simply scale the model after Transfer Utility, but unfortunately there seems no way to scale the clothing once it’s ‘Fit To’ Genesis.
I’d really like to start making some content, but can’t seem to get past these issues.
Thanks in advance!
