Digital Art Zone
1 of 2
1
mcjAudioMation - Animations from audio files—First version Released !
Posted: 02 October 2012 08:08 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2006-01-19
download and manual here——> https://sites.google.com/site/mcasualsdazscripts2/mcjaudiomation
History
Oct 8 2012
—released
Oct 19 2012
—added a key component ( mcjAudioMation.dsa ) that was missing in the initial release. Without this component the Daz script sproduced by the program don’t work !
mcjAudiomation is a small Windows/PC application which takes uncompressed audio (.wav) files
and create an animation script for Daz Studio 1,2,3,4
in the case shown here, the animation was applied to the “open mouth” morph of the EmotiGuy’s head,
to the “PushPull” morph of the speaker
and to the YTranslate channel of the green ball.
an other use could be to shake a camera, rotate the needle on a meter.
it can also be used as visual cues when synchronizing an animation to an audio track
added : it can also export the animations as Poser Pose files PZ2
added : it can create sonograms/spectrograms which let you see sounds through time and across frequencies
Video demos !
https://www.youtube.com/watch?v=SbAYrDQStwQ
https://www.youtube.com/watch?v=ylgCC_qx_bI
http://www.youtube.com/watch?v=vL0SagfjLa0
https://www.youtube.com/watch?v=A00IGswaR-g
Image Attachments
Profile
Posted: 03 October 2012 09:01 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
here i applied the animation to the ZScale channel of a black primitive-plane that masks some of the LEDs
when the sound-level is near zero, the mask is scaled 260% and covers the whole column of LEDs
when the sound level is maximum, the mask is scaled 0% and doesnt cover any LED
the needles of the VU meters get their YRotate rotation animated between 42 degrees and -42 degrees
for now there’s only 1 animation channel even if the music is stereo, but this will change in the release
Image Attachments
Profile
Posted: 04 October 2012 05:01 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
now in stereo
so, first picture: i run the Windows app named mcjAudioMation
i select and load an audio file
i export the processed audio as a .dsa daz studio script
second picture i select the VU Meter’s needle
i run the script that was produced in step one
i adjust the multiplier and offset so that, the needle’s YRotate angle will vary between +42 and - 42 degrees
the animation comes from the Left channel o f the audio
Image Attachments
Profile
Posted: 04 October 2012 06:26 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
video demo : stereo animations
http://www.youtube.com/watch?v=ylgCC_qx_bI&feature=youtu.be
Image Attachments
Profile
Posted: 04 October 2012 07:12 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2005-03-26
I don’t do much animation, but I may have to try this out.  It reminds me of the Player Piano .PY scripts from VanishingPoint, but more versatile.
 Signature
God still reigns.
As a cultural historian, Dawson understood that the core of a culture is found once we locate the thing that the culture would never relinquish, or even imagine itself relinquishing. I submit that in our case it is not individual liberty, or sex, and certainly not religion. It is not even the machine. Rather, it is the machine insofar as it promises an activity superior to the human act. ~ RUSSELL HITTINGER
http://eustacescrubb.deviantart.com/gallery/
Profile
Posted: 06 October 2012 12:37 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
the script will be able to export the animations as daz scripts, and, drum rolls, as Poser pz2 pose-animations
so it should be usable by Poser and Carrara users too !
the program is basically ready, i’m running some test and making a 30 seconds dance video, which of course took almost as long as writing the program smile
Image Attachments
Profile
Posted: 07 October 2012 10:36 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
demonstration video !
http://www.youtube.com/watch?v=SbAYrDQStwQ
images attached
spectrogram or sonogram for the demonstration video
2nd image is the sonogram for a 6 seconds speech ( synthesized voice ) and uses a logarithmic scale for the power/brightness
3rd image is log-scaled sonogram for the demonstration video
Image Attachments
Profile
Posted: 08 October 2012 04:59 AM   [ Ignore ]   [ # 7 ]
New Member
Joined  2008-06-25
I’m very much looking forward to this release. It ought to save me a lot of headaches synchronising an animated bass drum to its music soundtrack. Plus it seems to offer plenty of scope for experimentation, especially with dual audio inputs from a stereo soundtrack.
Profile
Posted: 08 October 2012 05:53 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
CleverApe - 08 October 2012 04:59 AM
i’ll release it today, hopefully before noon (eastern time)
if you watch the video : http://www.youtube.com/watch?v=SbAYrDQStwQ
the simplest thing is to animate the rotation of a needle ( it’s in fact a primitives-cylinder )
then animate the drummer’s stick with similar timings
Image Attachments
Profile
Posted: 08 October 2012 05:57 AM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
the new look of the sonograms produced by mcjAudioMation
( this was rescaled using a paint program )
the user manual will contain instructions about including this “sonogram” in your Daz Studio scenes, and using it as a synchronization helper
Image Attachments
Profile
Posted: 08 October 2012 08:00 AM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
i think the programming is completed here’s the UI
not very cute but it should work on all Windows version since 1995
Image Attachments
Profile
Posted: 08 October 2012 10:04 AM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
in case anyone’s impatiently awaiting the release
the user manual’s writing has begun
and after lunch the download link shall appear at the bottom of the page
( before posting the program, i just want to make sure it passes the tests done during the writing of the manual )
Profile
Posted: 08 October 2012 11:38 AM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
~ Delay News ~ ~ Delay News ~ ~ Delay News ~ ~ Delay News ~ ~ Delay News ~
well, while writing the manual i discovered that, the program was doing well for producing poser-pose files usable on props, but the poser-pose files dont work on figure morphs , and i need to fix that.
so .... tomorrow maybe you’ll have the program smile
and the manual
unrelated image to make the post less boring
Image Attachments
Profile
Posted: 09 October 2012 01:28 PM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
first version is ready !
i moved the Poser Export Settings to a dialog window, it’s neater this way
later i may post an update with some speedups
Image Attachments
Profile
Posted: 15 October 2012 05:27 PM   [ Ignore ]   [ # 14 ]
Member
Avatar
Rank
Joined  2008-06-25
Stunning. Thanks a lot!!
 Signature
do your research before blaming 3Delight for shortcomings of your renders
dA gallery link in profile along with anything else you may need to know about me
Profile
Posted: 18 October 2012 10:30 PM   [ Ignore ]   [ # 15 ]
New Member
Joined  2008-06-25
The pz2 file method seems to work very well. I haven’t been able to use the dsa method, because the pop-up that’s supposed to appear hasn’‘t made an appearance. I don’t know if it’s the software, of just a foible of my computer (XP SP3, Daz 3). The content of the dsa files created are lists of numbers, with nothing else at the end of the file. I hope that helps.
Thanks for this Casual. Like your other software - especially the spline smoother, and the materials animator - this stuff will come in very useful.
Profile
1 of 2
1
