So for instance a belt. I have the figure… I load up the belt, by default it auto fits (Must be ‘Fit To’ Otherwise it wont conform to the genesis morphs)
Say the belt is too high up the torso for what I want, When I select the belt prop, It wont Rotate, Scale or Translate no matter how high the value. How would I get around this?
That’s easy, right click the item in the Scene Tab, and pick change Parent to none, it will stay right were it is but is no longer FIT to genesis you can now move scale rotate all you want. When you finish you just do the Drag and drop Parenting trick to get it to follow the figure. Open the Genesis figure in the Scene Tab and then drag the prop to the part of the body it needs to follow.
You can not parent to more than one part at a time, so if you rotate the belt to go across the chest when it loads on the hip by default it will no longer follow all of the figure. The prop would need to be re-built as a Genesis clothing item made to cover (follow) more than one part of the figure. That can be done if you go read some of the clothing threads that are on the forums now.
P.S. Faster way is to just change Fit To in Parameters to None and then edit followed with the Parenting.
Jader, I’m just holding off on the flint pack for further information on the smoothing export. Either that, or I can create the textures for the ones that work then make them all PP2 and email them to you. The later will expect them ready in a few hours (Excluding the bent spear)
You take your time and do what you really wish to do. I’m going to tell you up front, when I get my hands on those tools I’m going to run off and start playing with them. I’m already days behind on this expansion and I’m only one pose into the Tribal Bow pose set. You give me those anytime soon and POOF! I will be off on another tangent so fast your head will spin. I might just disappear for days before I surface again
LMAO Well I take that as a compliment… Oh are you still on your DA, I got an Idea and commented it on your pic… Perhaps a future render collab *Raises one Eye brow like Dwayne the Rock Johnson*
Hmm… Ideas, Ideas, we would both need the same Enviro and Light set up. Then render in layers so they could be postworked into a final render but it is doable. But your Tribe looks so much more advanced than mine. My folks have not even invented the bow yet.
Yeah I know! That’s the thing… “The Others” Stuck in time, or lost in the future. Lights will be okay I think same as the camera.. We exchange the light parameters, a screenie of the settings of each cam/light. We render as PNG with No background, then we agree on the best bkg or blend two bkg’s in post work.
