Digital Art Zone
OS X 10.8.2, C8.5-172, very slow renders and crash
Posted: 02 October 2012 05:38 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2008-08-29
I recently got an iMac and have been using Carrara on it. This has been very nice because it renders four times faster than my old system, but I have encountered a problem with my latest scene.
The scene isn’t particularly complex with two props, m4, v4 and conforming clothing. And dynamic hair for grass—but that’s nothing compared to a recent scene with numerous objects, high counts for dynamic hair (three sets), etc., etc. The current scene rendered fine when I did tests to see how it looked, but when I went to do a final render I noticed it was going very slowly—the CPU was at 25% utilization! (reported as 200%, out of 800% due to four core with hyper threading). Normally it is around 750% utilization so I looked for causes and tweaked the render settings.
There’s no disk access going on with plenty of free memory. No other processes are taking up much CPU. I went back to the previous settings and with other tweaking managed to get a little more utilization (reported as 250%). Well, I let it run and did some editing in a text file so I wasn’t watching and don’t know how far it got, but not very far based on time elapsed, when Carrara crashed.
I can’t really see anything to either cause a low CPU utilization render or to induce a crash. I’ve been on 10.8.2 for nearly as long as I’ve had the computer and have rendered for ~8 days solid (batch of multiple scenes) without mishap. So I’m at a loss.
I’ll be trying the render again in a bit, but it will take a while due to the slowness to discover anything. Anyone else on OS X experiencing these sort of issues?
 Signature
Swamp Living Never Felt So Good
Profile
Posted: 02 October 2012 06:18 AM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2003-10-09
thoromyr - 02 October 2012 05:38 AM
Carrara on newer versions of OS X can be a bit problematic, although I haven’t seen the exact behavior that you describe.
Please go to the DAZ Bug Reporter and file a bug report with as much detail as you can manage, as this will help DAZ sort out the problems before C8.5 ships.
 Signature
http://bytescapes.com/            Bryce/Carrara/Reality galleries and resources
Profile
Posted: 02 October 2012 07:18 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2009-03-09
If you are on 64-bit, then turn off texture spooling.  (File | Preferences, Imaging and Scratch Disk, uncheck “spool texture on disk”).  Texture spooling on 64-bit Carrara causes symptoms like you describe.
 Signature
Come visit my store!
http://fenric.com/wordpress/store/
Profile
Posted: 02 October 2012 09:19 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2008-08-29
angusm - 02 October 2012 06:18 AM
Well, if it was reproducible (even intermittently) I’d certainly do so. I started the render again and it goes slow but it got much further without crashing (I aborted because I discovered a mistake). I certainly want to get bugs reported before they stop the beta…
 Signature
Profile
Posted: 02 October 2012 09:21 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2008-08-29
Fenric - 02 October 2012 07:18 AM
Ah hah! Interesting. It also causes problems when running Carrara in Wine. Thanks and done!
 Signature
Profile
