Digital Art Zone
Need some help with Explode modifier
Posted: 01 October 2012 07:25 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2007-03-03
I’m working on an explosion of a small, spherical object.  Right now, I have a particle emitter inside that works nicely and I also want to Explode the outer “shell” to go with it.  The problem I’m running into is that the fragments don’t go very far, even with Speed set to 1.  Is there a way I can get them to spread at a similar rate of the particles from the emitter?
 Signature
-Kodiak3d
“I wonder what tomorrow has in mind for me, or am I even in its mind at all?”
- “Crystal Ball” by Styx
Profile
Posted: 01 October 2012 09:37 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
Hi Kodiak
just scale the sphere up at the end so the scale is expanding during the animation
if you make the peice sizes smaller at the end then it won’t look odd
 Signature
http://andrewfinnie.blogspot.com.au/
Profile
Posted: 01 October 2012 10:01 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2007-03-03
Jeez, why didn’t I think of that?  I feel kinda stupid, but thanks for the idea grin
Note:  Tried, it, and it’s not quite what I was looking for.  Still, it did give a neat effect I’d like to work with.
 Signature
-Kodiak3d
Profile
Posted: 01 October 2012 10:20 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
Heh that’s why we have a forum… next time I am stuck I bags you give the answer wink
T’other ting you could try is Carrara physics to blow meshes outwards ?
 Signature
Profile
Posted: 02 October 2012 04:46 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2007-03-03
Tried that, but the pieces seem to still be considered part of the same whole and don’t react individually to any forces.
 Signature
-Kodiak3d
Profile
Posted: 02 October 2012 06:44 AM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi Kodiak smile
The easy answer is to use the Visibility option to key-frame the disappearance of the sphere object, (just after explosion) and to use another particle emitter to emit (shards) which look like parts of the object being blown up.
add some smoky particles, and you shouldn’t notice the original sphere vanishing.
the more complex answer would be to “build” the object you want to explode by creating a bunch of chunks inside your original mesh,.. and use physics.
smile
Profile
Posted: 02 October 2012 10:32 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2007-10-08
There are a series of videos and tutorials on the CarraraCafe.com site under tutorials. Here is a link to the page where they start with the Bullet tutorials.
http://carraracafe.com/?page_id=1382&paged=5
Have fun!
Profile
Posted: 02 October 2012 02:44 PM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2007-03-03
3DAGE - 02 October 2012 06:44 AM
smile
Yeah, I’ve started that.  I think it’s the only answer, but I’m also going to check out the link bfurner supplied (thank you, btw).
Thanks for the help, everyone.
 Signature
-Kodiak3d
Profile
