...When I’m trying to model .hot key a, hot key c ,right click etc etc.
I never got past it ,I never will.
I just don’t get why Blender makes stuff so complicated.
It slows me down to the point I just won’t use the app…
I tend to not like a lot of hotkeys as they are usually one more thing to try to memorize, slowing down the learning curve. Blender’s hot keys are different though for me. They are very intuitive. R for rotate, S for size, A for select all, shift+a to pop up an ‘add’ window to add meshes, cameras etc.. They are *so* intuitive that they don’t require the typical brain resources other hot keys do. The benefit is that one can hit ‘S’ for size, immediately followed with x/y/z to constrain the axis while the other hand remains on the mouse and drags… drastically speeding up things from having to relocate the mouse all over the screen to do each action. In short, Blender is the one program that has changed my mind about shortcut keys.
The faster app’s you don’t need to hit a,c,right click .you just click on the vertices ,it’s faster ,less complicated that way.
It’s back to basic philosophy…Blender was originally designed to be keyboard driven, not mouse driven (or graphics tablet).
I’m explaining this wrong ,let me try again.
LW ,Softimage are hotkey driven.Blender ,LW ,Softimage fells a lot a like to me.
trueSpace ,C4D have icons but you can use hotkeys.C4D has a LW UI so you can make C4D look and work like LW.
lets fore get about the hot keys.mouse or wacom.
the faster app’s it’s less steps to select a vertice.
I’ve said steep learning curve, too. :-D A shortcut-based interface is very powerful but also vastly counterintuitive, as it has to be learned by memorization and you can’t just look for the right button on a toolbar.
I have 2.49b 32 bit (for great scripts that were never updated), 2.49b 64 bit (for faster versions of those scripts that were updated to 64 bit but not to the 2.5+ series), and 2.63 64 bit for my everyday workflow. All of my products are made in the new series for many months now. Blender’s ability to have versions installed in parallel without forcing you to uninstall old ones is one of its great features - if something is deprecated and never replaced, you can port objs back and forth between versions to use it still.
If you use 2.49b, it’s really worth at least adding 2.6+ to your workflows, because it’s so much faster and better optimized. I also hate UI changes, but almost all the shortcuts still work; the biggest wrench for me was the switch from b and b,b for bounding box and circle to b for box and c for circle. And the sculpting alone is just fantastic in how much it’s improved. I use it on every product now where it was barely practical to use at all in the old one. I feel cloth sim is still pretty flawed, but it has its uses and that hasn’t changed.
Not only that, but you can easily create your own import, export, and sim presets with 2.5+, which is invaluable if (for instance) you know you’re going to be exporting the same mesh five times in an hour as you check and adjust geometry before rigging.
...which is why I like it. I come from the days when a “mouse” was known only as a household pest or a critter they used in labs to test drugs on. I really hate how so many apps like the MS Office ones have become so mouse dependent. I find having to take my hands away from the keyboard actually interferes with my workflow.
Yeah 3DS, C4D & such are slicker and have more features, but that’s why people pay the big zlotys for them. Blender comes pretty darn close though, close enough for my needs.
Personally I believe it was designed for one hand on the keyboard and another on the mouse or tablet, which is the most efficient way to work if they shortcuts are intuitive enough. Watching any good speed time lapses in Blender and that’s what they are doing. People will often have keyboard keys showing onscreen (a setting in blender) so people can keep track of what they are doing because they are constantly using keyboard synchronized with mouse/tablet where other packages they are popping up menus. In this example he didn’t have keyboard keys showing unfortunately, but it’s still a cool time lapse
I did a search through all my old backups…and the first time I downloaded Blender was back in 2002. I found it on the Nov-Dec disk. Blender was released to the public in Oct of 2002. I didn’t think it was strange, back then, that you could work in it without even having to have a scrollwheel mouse. The interface was different…but usable. It’s come along way in the past ten years. It’s going to be 10 on the 13th…
Personally, I think Blender rocks: the only alternatives are madly expensive or worse still, are clunky and expensive. Blender is also the only decent 3D program for Mac people like me unless (once again) you have thousands to fork out and weeks to learn another weird and illogical interface. In Blender, the X key means X axis and so on. It may seem crazy, but some other pricey 3D apps don’t even do that.
I can’t say i like all the ongoing changes but I am happy that the latest version now has a good knife tool (it was missing from 2.5 series) - I just wish it were not so time consuming to model and rig - which is where DAZ is great. I find they make a good combo.
Anyone needs hints or help with using Blender, I might be able to assist. I have been using it since 2.4 although I would not claim to be an “expert” (whatever that is)
1998 softimage was $20,000 Max 2 or 3 was $3,000 ,LW 2 or 3 $2,000.
LW 7 was only a $1000.
Now Max owns Softimage.& Maya.
Part of LW left and made Modo.
At one time Blender was sold ,no one boult it so they made it free..
Same with truespace but Microsoft abounded trueSpace.
2012 All main CGI app’s are still in the stone age.
Model 100% quad rule Most ridiculous rule ever made.
Modeling App’s don’t support nGones.
I could go on & on but I’ll stop here.
Maybe if society makes it to 3012.
CGI will get there.
But for now I’m not impressed with any of them.
They all have major flaws no matter the cost.
Isn’t that new since the Big Update that started with 2.5, though? It used to be you would get an error message if you created, say, a line pentagon and tried to F-key fill it.
believe part of bmesh, 2.62/2.63? But yes it’s new, and I’m guessing if one exports to renderer it might quad/tri, but that wouldn’t be Blender but the render engine that wouldn’t support ngons at that point.
You are right on Gedd - and just for the heck of it, I imported models with ngons into DAZ4 Pro and they worked just fine despite a report here in the forums that it would not work. I found that later !
Personally, ngons in Blender saved me a heck of a lot of mucking around and thousands of verts.
As for faults? show me any software without bugs. ANY software.
It’s more about the type and severity of the bugs - Blender I think is relatively good that way, but then it is so big that I have not tried all of the functions/toolsets out.
