I have installed the ArchiTools 64 bit plug-in into Carrara 64 bit but when I select the building icon I get an error message which states that the version I have is a network rendering version and it says install the proper version. I also tried the 32 bit version in Carrara 32 bit but get the same message. Does anyone know why this is happening.
I am using 64 bit Windows 7 system.
Problem solved with newer version update. This can be removed.
