Taozen - 02 October 2012 11:40 AM
launok - 02 October 2012 06:44 AM
@ Taozen,
I have tried to download via your tool but it’s not working and I do have the Microsoft network file needed on my system in order for this to work. I am on Win XP sp3.
I have made a print screen of what is happening while downloading. I eventually had to stop the download process as almost all my files for DS4.5 free version had the same problems as in this print screen.
I assume you’re having problems with downloading from DAZ with other programs and browsers as well?
Have you always had problems with downloading from DAZ or did it first start after the problems with the DAZ site a few days ago?
As for making a downloader for ShareCG it won’t make much sense the way that site works, and I doubt it would solve your problems anyway since everything seems to indicate that they’re caused by either your system (e.g. network settings, firewall setup), your network connection, or your ISP.
You could try to run some of the tests at dslreports and see if they report anything unusual.
http://www.dslreports.com/tools
Taozen, thanks for reply. Normally I can download from DAZ quite successfully. I can remember though during the 1st time I have downloaded the free Hexagon 2, Daz Studio 4.0 and Bryce 7.1 when it was released free earlier this year, all the files downloaded successfully except the Bryce 7.1 content I tried several times, even after resetting, with no luck! If I remember correctly, the size was about 600+ mb (nowadays one can’t see sizes) and it would go up to say about 350 mb and stops there, sometimes more than that, other times less. I am now still using Bryce 7.0 contents with 7.1 version. The larger files seems to be problematic, although DS4.0 downloaded fully which was about 430 mb.
To answer Mari-Anne’s question, I am using the download tab next to the files listed in the download section at DAZ.
I am not sure if this could be the problem but since my computer was formatted and my brother installed Win XP with SP3, I am having problems especially at ShareCG. Prior to the format I used Win XP SP2 for a long time and downloads went actually great at ShareCG and Daz3D as well as other sites. Both Firefox and IE7 do same thing at DAZ & ShareCG but normally Firefox works and download greatly. I had tried IE8 but most of the time my pc crashes, even IE7 has given me problems and I actually prefer Firefox which doesn’t crash at all! IE is really a pain! I will give that “dslreports” a try and see what it will show.
I am on ADSL but MWEB in South Africa (my ISP) numerous times has problems with Seacom international cable, not sure how stable it is lately. For instance, last night (midnight) the speed was all of a sudden only 4-8 kb/second (and very unstable) whereas normally I can download between 25-30 kb/s or more at that hour as traffic is less then. Today better though but not quite what it should be. I have the smallest speed modem for adsl as I can’t afford as pensioner higher speed modem monthly costs. But even with this modem I get good download speeds for my needs, only now in some incidents having problems. I will try DAZ downloads again after resetting later in the week and see what will happen then.
Regards,
Laura
