Digital Art Zone
8 of 9
8
Utility to repair damaged Installers Available
Posted: 28 June 2012 09:22 PM   [ Ignore ]   [ # 106 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Slimer_J_Spud - 28 June 2012 09:14 PM
Kendall Sears - 28 June 2012 08:46 PM
Tonight, all of the downloads I received had a smaller, but different error at the end.  Hopefully, this is a transitory thing.
Kendall
The new downloads I have all have a hex 0A” at the end, but nothing else. I’ll try resetting an old generation installer and downloading.
This is at the end of all of the files downloaded this afternoon:
0A 46  61 74 61 6C  20 65 72 72.Fatal err
6F 72 3A 20  45 78 63 65  70 74 69 6F  6E 20 74 68
or: Exception th
72 6F 77 6E  20 77 69 74  68 6F 75 74  20 61 20 73  rown without a s
74 61 63 6B  20 66 72 61  6D 65 20 69  6E 20 55 6E  tack frame in Un
6B 6E 6F 77  6E 20 6F 6E  20 6C 69 6E  65 20 30 0A  known on line 0.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 28 June 2012 09:40 PM   [ Ignore ]   [ # 107 ]
Active Member
Avatar
RankRank
Joined  2010-12-13
Good grief! I didn’t get that. Well, the error still starts with “0AFatal error: ” (0A 46 61 74 61 6C 20 65 72 72 6F 72 3A 20). Looks like that ray of hope was premature. Looks like your magic is still needed.
 Signature
Old post count 1725 (seems lame compared to some)
Profile
Posted: 28 June 2012 09:52 PM   [ Ignore ]   [ # 108 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Slimer_J_Spud - 28 June 2012 09:40 PM
I’m hoping that won’t be the case.  I’ll hold off on an update unless someone needs it.  Hopefully, DAZ will get it fixed quickly.  At least there’s only 1 error this time.
Kendall
 Signature
Profile
Posted: 05 July 2012 12:33 PM   [ Ignore ]   [ # 109 ]
Administrator
Avatar
RankRank
Joined  2004-02-13
I am going to go ahead and unsticky this thread as there is a link to it in this thread here: http://www.daz3d.com/forums/viewthread/115/ as well so everyone can easily get to it. Just wanted to let you all know so you didn’t wonder how to find it or where the sticky went smile
PS TY Kendall for this utility and for helping with this issue! smile Though I think I told you that before but it never hurts to say it yet again smile
 Signature
Aundrea M Anderson (ann0314)
DAZ3D Community Volunteer Program Manager
DAZ3D PA/Customer Relations Liaison
Co-Owner of ARTCollaborations
Profile
Posted: 05 July 2012 12:37 PM   [ Ignore ]   [ # 110 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
DAZ_ann0314 - 05 July 2012 12:33 PM
Considering that the utility is no longer needed, unsticky-ing it is fine by me.
Thanks
Kendall
 Signature
Profile
Posted: 05 July 2012 05:12 PM   [ Ignore ]   [ # 111 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
You said the utility is no longer needed; so this means all the downloads are fixed now?
Profile
Posted: 05 July 2012 05:17 PM   [ Ignore ]   [ # 112 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Sean Riesch - 05 July 2012 05:12 PM
Not completely.  The error changed on 6/28 and the utility no longer strips it, but no one has contacted me about updating the utility.  So, I assume that since no one is having issues worth asking for a fix for, the utility must no longer serve a purpose.
Kendall
 Signature
Profile
Posted: 05 July 2012 05:48 PM   [ Ignore ]   [ # 113 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
It might not be a lack of interest that you haven’t had requests.  For example, I hadn’t actually tried your utility yet only because I didn’t need to use my purchases immediately and figured I could just wait a bit until DAZ gets the issue resolved, then download them then.  However I’m starting to wonder how long this will take (days? months? soons?)  If this isn’t fixed this month either, I’d give your utility a try.
Profile
Posted: 05 July 2012 06:44 PM   [ Ignore ]   [ # 114 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
I don’t intend to remove the utility from my site for quite some time, so for those files downloaded prior to 6/28 it’ll probably continue to fix the problem.  For files downloaded after that date until the complete fix, I’ll have to write an update if I get any interest.
Kendall
 Signature
Profile
Posted: 12 July 2012 08:16 PM   [ Ignore ]   [ # 115 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
OK Folks!
I have updated the Mac version of the download utility.  Windows will come a little later this evening (I hope).
By popular demand, this new version appends “-fixed” to the archive name before the extension.
EDIT:  WIN32 and 64 versions uploaded.
Kendall
 Signature
Profile
Posted: 13 July 2012 12:27 AM   [ Ignore ]   [ # 116 ]
New Member
Joined  2012-03-03
I have downloaded your utility (thank you) but I don’t quite understand how to use it.  What do I put in the Input File and Output File?  Yes, I’m pretty hopeless…
Profile
Posted: 13 July 2012 06:16 AM   [ Ignore ]   [ # 117 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Nolamom3507 - 13 July 2012 12:27 AM
If you’re using Windows make sure that you download the archive named newFixDaz.zip
Once you extract the version you want (32 or 64 bit), run it.  Click on “Browse” next to the input area and select the downloaded installer that is having problems.  The utility will automatically fill in the output.  Click on “Go”. If the error is one of the supported errors that can be fixed you will see “Done.”  You should now have a version of the installer in the same location as the original with a “-fixed” in the name.  If you see any other message, then you have a different problem and will probably need to “reset” and “redownload” the installer.
Kendall
 Signature
Profile
Posted: 14 July 2012 08:08 PM   [ Ignore ]   [ # 118 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
I tried running FixDaz32.exe on the re-downloaded IM00004019_daedalus-sky-mercenary-for-m3.zip, but get the message “No error found in a reasonable space.  Assuming no problems.”  I’m guessing this .zip is corrupted in a different way and not fixable by this utility?
Extract All on the .zip in Windows XP gives me “Unexpected end of file.”, and in Windows 7 it gives me “An unexpected error is keeping you from copying the file. If you continue to receive this error, you can use the error code to search for help with this problem.  Error 0x80004005: Unspecified error
!!!VIS.pz2
Type: PZ2 File
Date modified: 1/25/2006 1:40 PM
Profile
Posted: 14 July 2012 08:13 PM   [ Ignore ]   [ # 119 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Sean Riesch - 14 July 2012 08:08 PM
!!!VIS.pz2
Type: PZ2 File
Your download most likely got cropped.  My utility can’t help with that grin
Kendall
 Signature
Profile
Posted: 25 July 2012 02:45 AM   [ Ignore ]   [ # 120 ]
New Member
Joined  2010-05-24
Kendall Sears - 29 May 2012 03:11 PM
New versions available for download.  Handles new problems for those in need.
Kendall
...Just wanted to say thanks on behalf of the MAC users, too.
Profile
8 of 9
8
