Hi. I’m using Carrara8.5 beta and Mimic for Carrara with the updated files for Genesis.
What’s the best way to capture the mimc data (the sequence of Phonemes) into an NLA clip?
Here’s what I’ve tried so far:
I brought in a lengthy clip (vocals from a song), and two subtracks, one called Phonemes and one called Gestures show up as expected in the Sequence area/timeline, under Genesis>Track.
If I look in my Clips area at bottom right of the interface (Instances/Objects/Shaders/Sounds/Clips), the Gestures track shows up as a clip which I can then add to my browser under clips for later use.
The Phonemes track does not show up, however.
I tried to select and copy/paste the phonemes into a new editable clip and save that as a new Master Clip - but none of the data is actually captured.
Is there a current bug in C8.5 preventing this or am I doing something wrong here?
I don’t remember this (getting Mimic stuff into nla clips) being a problem in the past.
Thanks for any help.
