Digital Art Zone
Push modifiers and favorite parameters?
Posted: 23 September 2012 03:35 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Can someone explain what push modifiers are? I kinda wish someone could at least mention what new features are for when they’re added.  wink
Also, is there no longer any way to save certain parameters as Favorites? I really used to like having commonly-used dials like Eyes-UpDown and the head bending morphs easy to find (especially with Genesis and its gazillion morphs spread all over creation).
Thanks in advance.
SnowS
 Signature
“It answers all the questions, finally, but not really, but kind of”
- Bob Denver
my deviantArt page: http://snowsultan.deviantart.com
Smacky icon by Xamag
Profile
Posted: 23 September 2012 03:40 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
The push modifier moves the mesh in or out a bit, like an overall displacement. If you want to use one of the body hair or second skin overlays, instead of loading a full second copy of the figure you can create a geometry shell, apply a push modifier with a low value, and apply the overlay to that getting the same result with lower overheads. You could also use a push modifier as a poke-through fixer.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 23 September 2012 03:48 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Ah, thanks. I thought that sort of adjustment was only for geometry shells.
Do you also happen to know why some Genesis clothing fits fine when it’s first applied but when the saved scene is reopened later, it doesn’t fit properly? Do we have to apply smoothing modifiers to any clothing that does that?
Thanks again.
 Signature
- Bob Denver
Profile
Posted: 23 September 2012 04:04 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2006-09-05
Please, can you explain the menu’s voices to do these passages?
 Signature
http://mcmxc2.deviantart.com
Profile
Posted: 23 September 2012 04:15 PM   [ Ignore ]   [ # 4 ]
Power Member
RankRankRank
Joined  2005-09-05
MCMXC - 23 September 2012 04:04 PM
Does anyone know a step by step tutorial for doing this? Something simple so my brain doesn’t melt out of my ears…
 Signature
Shadermixer tutorials and recipes
My Website
My ShareCG Gallery
Shadermixer Documents
Profile
Posted: 23 September 2012 04:48 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2007-12-07
Pendraia - 23 September 2012 04:15 PM
There are probably keyboard shortcuts, but ...
a) Select the figure/prop in scene tab/viewport.
b) Create> New Geometry Shell (should be at, or toward bottom of menu)
c) Accept the default options in the dialog box (Parent to selected item), but consider giving it a useful name
You will now have a shell displaced by 0.1 cm.
In the Posing tab, under Parameters, with the shell selected, you will have a Mesh Offset item, which will adjust the displacement/offset of the shell from the host figure/prop.
You will also have the Shell entry under Parameters, which expands to Visibilty, and then to Surfaces and Face Groups.  You can control, with a simple on/off click what parts of the shell are visible, based on either the underlying figures material zones or by names of the bones that make up the figure.
The shell inherits the UV map of the original figure so you can ‘paint’ the shell with all the usual MAT poses or shaders.
You can apply a Push Modifier to things too.  Do this by selecting the item and using the ‘conetext menu’ (the little box at the top right of the tab, with 4 horizontal lines and a small right-pointing arrow) and selecting Edit> Apply Push Modify.
This will add the ‘Mesh Offset’ parameter, allowing you to ‘push’ or displace the given item as desired.
You can undo the effect with Edit> Remove Push Modifier if you so wish.
 Signature
Some writings by a friend:
http://www.lizardsofthehost.co.uk/11.html
http://www.lizardsofthehost.co.uk/13.html
http://www.lizardsofthehost.co.uk/7.html
Profile
Posted: 23 September 2012 04:52 PM   [ Ignore ]   [ # 6 ]
Power Member
RankRankRank
Joined  2005-09-05
SimonJM - 23 September 2012 04:48 PM
Thanks for that, you explained it beautifully!
 Signature
My Website
My ShareCG Gallery
Profile
