HI Lazaruszi
Since it’s my clip, I better explain how I did it
It’s a trick. / illusion.
Carrara particles have NO Volume,. they’re flat, and don’t build up. ...so,. you need to fake it.
The Glass has an object inside it (the fluid) and that object has a couple of Morphs, to make it “Fill Up” the glass.
the main particle emitter, uses a “Meta Particle” which looks like a fluid / liquid. and the particles collide with the glass.
The “fluid” object in the glass, is animated to change the morph and “Fill the glass”.
Hope it helps
