Digital Art Zone
C8 used different settings of light?
Posted: 21 September 2012 10:48 PM   [ Ignore ]
Member
Rank
Joined  2005-02-17
Hi all,
I set the intensity of default distant light from 100 to 70.
Rendering of current frame is ok.
Rendering of movie used old setting (100).
What should I do? This happens even I exit the prg and restart again.
I am using ver 8.1.1 build 12
Thanks in advance
Profile
Posted: 22 September 2012 07:43 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi Sam smile
I’ve just tried this , but if I set the distant light to 70, then render,.. the light strength remains at 70 (or whatever value it’s set at),. when I go back to the Assembly room, the light is still at 70 (the same value). so, for me, the light renders in a movie (or still image) with the correct settings.
Where are you seeing that it’s changing to 100 ?
EG: in the render settings, or,.. in the scene,.. Assembly room.
Any screen-captures / pics are always helpful smile
Profile
Posted: 22 September 2012 09:22 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2005-02-17
Hi 3Dage,
I try to start from scratch to see if I can repeat this problem again.
Profile
Posted: 23 September 2012 10:14 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
It’s possible you inadvertently set a keyframe for the light intensity. If you moved along the timeline and changed the light it would create the keyframe automatically. Look to see if there’s an unwanted keyframe for the light.
Profile
Posted: 23 September 2012 11:17 AM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2005-02-17
Thanks a lot.
My mistake raspberry I changed the light intensity at frame 30. When I rendered current frame, it is ok.
However, when I rendered movie starting from frame 1, light intensity is still 100 on frame 1!
Profile
Posted: 23 September 2012 11:32 AM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
That is a very easy mistake to do. One on which I’m sure almost everyone here has done at least once- if not more. wink
Profile
