Digital Art Zone
1 of 2
1
How to import Daz Studio 4 model in sketchup pro 8?
Posted: 21 September 2012 06:03 PM   [ Ignore ]
New Member
Avatar
Joined  2012-09-03
Hello, I am a new user of DAZ STUDIO. Is it possible to import model (ex M4) in sketchup pro 8 (PC)? I tried to export OBJ file and import it into sketchup with a plugin but it does not work. Michael 4 is imported into sketchup without material ... all is white.
What to do?
Does anyone knows a solution?
excuse my bad English:cheese:
Profile
Posted: 21 September 2012 07:34 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2003-10-09
Have you ever successfully imported an OBJ file with materials into Sketchup?
What plugin are you using to import?
Is than any error messages, like “cannot find textures”?
Profile
Posted: 21 September 2012 08:05 PM   [ Ignore ]   [ # 2 ]
New Member
Avatar
Joined  2012-09-03
I never was successfully import materials ... only the shape of Michael 4… withe…
My plugin is obj_importer.rb’‘’‘
I discovered it on the SketchUcation forum:
# p172790 http://forums.sketchucation.com/viewtopic.php?f=323&t=20584
Profile
Posted: 21 September 2012 08:13 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
When you export the obj from DS, send it to its own folder (create one just for that item), make sure you have ‘write materials’ checked and then copy, into that folder, all the textures you need.  The mtl file doesn’t contain path information for the textures, just the file names.  So if they are ‘local’ (that is, in the same folder) they should be found, by whatever you are importing the obj into.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 21 September 2012 08:57 PM   [ Ignore ]   [ # 4 ]
New Member
Avatar
Joined  2012-09-03
Ok I’m doing a test.
Here are my presets:
Custum-
Invert-Positive Direction of XYZ = not checked
-Ignore invisible nodes = not checked
Use bone-welds = not checked
-Remove Unused Vertices = not checked
Write-Normals = not checked
Write object-statements = not checked
-Write Groups = not checked
Write-surfaces = checked
-Write Material Library = checked
No-maps-maps-Collect convert maps = not checked
I inform you of the result
Profile
Posted: 21 September 2012 09:01 PM   [ Ignore ]   [ # 5 ]
Active Member
RankRank
Joined  2003-10-09
Let me be clearer on this.
Have you ever successfully imported any OBJ with materials at all?
Profile
Posted: 21 September 2012 09:02 PM   [ Ignore ]   [ # 6 ]
New Member
Avatar
Joined  2012-09-03
sorry I made a mistake in my transcription.
no maps = check
Profile
Posted: 21 September 2012 09:03 PM   [ Ignore ]   [ # 7 ]
New Member
Avatar
Joined  2012-09-03
No
Profile
Posted: 21 September 2012 09:10 PM   [ Ignore ]   [ # 8 ]
Active Member
RankRank
Joined  2003-10-09
I believe the plugin you are using does not support UV maps, only material zones.
The only thing you can do with this plugin is possibly to change the color of materials.
The reason why M4 appears white is that is the diffuse color of the model (without textures)
Profile
Posted: 21 September 2012 09:26 PM   [ Ignore ]   [ # 9 ]
New Member
Avatar
Joined  2012-09-03
I also tried with Fluidimporter (http://www.fluidray.com/downloads?did=10), much faster and very accurate but also white ...
Are there other obj import?
Profile
Posted: 21 September 2012 09:54 PM   [ Ignore ]   [ # 10 ]
New Member
Avatar
Joined  2012-09-03
I followed the advice mjc1016 and it still does not work.
As Medzin think myobj import plugin should not manage the material ...
I search to find a new ...
I Thank You for your interest in my problem!
Profile
Posted: 21 September 2012 10:14 PM   [ Ignore ]   [ # 11 ]
Active Member
RankRank
Joined  2003-10-09
As you said, you are new to DAZ Studio.
But, do you even know how to use Sketchup?
You keep poking around with freebies you find who knows where on the net.
Did it occur to you to try a Collada import/export.  At least Sketchup has native support for that format.
Here’s another thing to think about.  If you ever do successfully import OBJ of M4 into sketchup, it will be a static object.
You will not be able to change the pose or expression.  Poser or DS rigging does not go over with OBJ format.
This is fine if you just need him to stand there like a statue, but is not much use otherwise
Profile
Posted: 21 September 2012 10:27 PM   [ Ignore ]   [ # 12 ]
New Member
Avatar
Joined  2012-09-03
I know sketchup.
I tried export collada but I had other problems. Position M4 is not imported, it is generated with initial cross position. And texture skins are multiplying in each polygon ...
To which the position is static, that is ok for me.
Profile
Posted: 22 September 2012 08:27 PM   [ Ignore ]   [ # 13 ]
New Member
Avatar
Joined  2012-09-03
Hello,
I did some test and I got a weird result.
Here is the path I have traveled:
In the software Dazstudio - I clicked ‘send to Hexagon’
In the software Hexagone - I exported my model file ‘Carrera’ (.car)
In the software Carrera - I export the model in OBJ file.
In the software Setchup - I imported the OBJ file with Fluidimporter
WOW! the road is long!
The problem is that the skin material is not placed correctly and that the eyes are absent.
Here is a picture that shows the result one time in sketchup.
Image Attachments
Profile
Posted: 22 September 2012 08:48 PM   [ Ignore ]   [ # 14 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Why not just Save your SketchUP scene as Obj files and load THAT into Daz Studio. I use SketchUP to make Props with Mats all the time. You will need to Tweak items (Size, and Materials, and add a light) but it works that way very well.
Just wondering…
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 25 September 2012 05:53 PM   [ Ignore ]   [ # 15 ]
New Member
Avatar
Joined  2012-09-03
I designing complex layouts of buildings in sketchup. I want to insert 3D models (made with dazstudio) which in my evolution models. And then make photorealistic renderings in Thearender that I master well.
Profile
1 of 2
1
