Digital Art Zone
V3 textures/MATs with Genesis?
Posted: 21 September 2012 10:19 AM   [ Ignore ]
Member
Rank
Joined  2010-02-05
Will Genesis ever take V3 (Gen 3) textures, MATs, skins, etc?
Profile
Posted: 21 September 2012 10:38 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2004-12-14
ragaray - 21 September 2012 10:19 AM
I doubt it.  Most of those textures won’t look very good in either current versions of DS or Poser.  Lighting in both programs has gotten much more accurate since the V3 timeframe.  A lot of them had effects burned into the jpg to make up for deficiencies in the lighting system.
If there are V3 skins you want to use, your best bet will be Texture Converter.
 Signature
“Facts do not cease to exist because they are ignored” - Aldous Huxley
Profile
Posted: 21 September 2012 12:23 PM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Also, the skin is split between the different maps in different ways on the third and fourth/fifth generation figures - as a result there are probably regions that would need bits of both the head and body maps from the third generation set, which isn’t possible within a single material zone (at least, not without help from Shader Mixer using a Mix brick). Texture Converter to any fourth geenration figure, then apply that to Genesis would work.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
