Hi all.
This is real odd.
I have installed Daz 4.03 (64 Bit)
I have used Daz before incidentally, so I know how things operate.
My issue is this.
If I make a prim from within Daz, I can apply textures to the surface thru the surfaces tab.
But if I import an obj file myself (from Lightwave), the object loads fine.
But when I load an image through the surfaces tab as before, (It can even be the same image I used in program) it does not appear on the surface let alone the render!!
What am I doing wrong?
Im not talking about a UV map, just a basic image on a planar surface.
What can be wrong here?
Regards Chris
