Digital Art Zone
stitching lines
Posted: 17 September 2012 08:51 AM   [ Ignore ]
Member
Rank
Joined  2011-06-17
  I need to know HOW do I get rid of those (green) lines you see on the figure when it’s rendered. They appear around the thighs, in the face (separating the face from the back of the head) and down the back. Is this what happens when take part of one figure and mix it with another?
Profile
Posted: 17 September 2012 09:05 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
They say a picture is worth a thousand words…can you post an example?
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 17 September 2012 09:19 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Probably, if you don’t have the correct UV Map for the skin you are using?
Profile
Posted: 17 September 2012 09:26 AM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2011-06-17
  IF this worked, This is the Brock figure.  you see the line going up his back and up the head, and around his thighs. I took the glossiness down to about half-way and set the lighting model at Skin.
Image Attachments
Profile
Posted: 17 September 2012 10:42 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
They look like texture seams, so the question is what is your shading rate at in the render settings ?
 Signature
**shuffles of with a new headache** tongue wink
Profile
Posted: 17 September 2012 01:23 PM   [ Ignore ]   [ # 5 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
YEP, looks like you will need to set Shading Rate to .5 or lower. That normally works Most Elite textures require it.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 17 September 2012 07:21 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2011-06-17
  Ok, I tried the Progressive shading, that took the lines out, and then set the SHading all the way down to .010 that worked better.  I went after a more natural look than the plastic glossy doll. When rendering the animation with the lower settings it takes a LONG time, but worth the results. THanks
Profile
Posted: 18 September 2012 02:18 AM   [ Ignore ]   [ # 7 ]
Power Member
RankRankRank
Joined  2005-09-05
texjones - 17 September 2012 09:26 AM
Have you changed the uv in the surface tab to M4?
 Signature
Shadermixer tutorials and recipes
My Website
My ShareCG Gallery
Shadermixer Documents
Profile
