Digital Art Zone
How do I use “Set HDR Candlelight”?
Posted: 16 September 2012 01:17 PM   [ Ignore ]
New Member
Joined  2012-09-09
I downloaded and installed DAZ Studio 4.5
http://www.daz3d.com/shop/daz-studio-4-pro/
Should it be used in the same way as “Set HDR KHPark”?
I found a tutorial (http://forumarchive.daz3d.com/viewtopic.php?t=173382) that uses “Set HDR KHPark” and that seems to work. However, if I try to substitute “Set HDR Candlelight” for “Set HDR KHPark” then my Genesis figure is rendered as totally black. I was expecting dim light…but I seem to get no light when I use “Set HDR Candlelight”.
How do I know if “Set HDR Candlelight” has been correctly applied?
Profile
Posted: 16 September 2012 01:27 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Steps I use. Load Uber Envro Base, Select the Uber in the Scene tab, Load Set HDR Candle, then go to Set Quality 4x
This is what I get with low render settings.
Image Attachments
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 16 September 2012 01:27 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
If you select the light, and look in the Parameters tab, there are loads of options to select.  Increase the Intensity percentage, and play around with the intensity itself.  These are shader lights, and there is a lot of learning involved.
There is also a help icon in the set, which will take you here to find out more : http://www.omnifreaker.com/index.php?title=UberEnvironment2
Profile
Posted: 16 September 2012 01:43 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2012-09-09
Jaderail - 16 September 2012 01:27 PM
Thanks for the quick reply. I guess that “candlelight” setting is intended to be very dark. I just tried the “dawn” setting and it is darker than what I expected for “candlelight”, but some features of the Genesis figure are visible.
Profile
Posted: 16 September 2012 01:46 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2012-09-09
JimmyC_2009 - 16 September 2012 01:27 PM
Thanks for the link to that page!
Profile
Posted: 17 September 2012 06:40 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
You might also find my “Learning UE2” thread (in my tutorials link below) useful as it covers a lot of detail about UE2. smile
 Signature
My Tutorials and Freebies Index
Profile
