Digital Art Zone
4 of 5
4
Recommendations for a rendering computer?
Posted: 24 November 2012 02:24 PM   [ Ignore ]   [ # 46 ]
Member
Avatar
Rank
Joined  2009-10-02
@LordHardDriven
Thank´s for the answer. But in the moment it is not a question of money but if it makes any sense. If Bryce can not more use as 4 GB RAM, then it´s better to take a SSD or a other CPU.
But the CPU I7 3770 K is a little problem for me to. Some say this CPU is slower as the I5 2500 K. And so I would rather decide for a good SSD.
Profile
Posted: 24 November 2012 03:17 PM   [ Ignore ]   [ # 47 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Roland4 - 24 November 2012 02:24 PM
@LordHardDriven
Well like I said, I’m not that well versed in the differences between the i5 and i7 but assuming what you said is correct then I would agree that the SSD is the better choice of the two.
Profile
Posted: 24 November 2012 06:03 PM   [ Ignore ]   [ # 48 ]
Addict
Avatar
RankRankRankRank
Joined  2012-04-07
I have no idea how much difference it makes with Bryce itself, however when I was making my purchase for only a few dollars more it was recommended to get the W7Pro as it handles [? if that’s the correct term] more memory than the regular W7. In other words, it was possible to add more memory to the computer than the OS could use ... but Pro could make it all usable. It works beautifully, haven’t even used the LAA [so far] for Bryce ‘cause everything is quite fast.
 Signature
A couple of tutorial re-ups for those wanting them.
Making skins [basic start]
Unpacking Zip Folders [i.e. how to deal with a gazillion folders if not using DIM]
Profile
Posted: 24 November 2012 06:14 PM   [ Ignore ]   [ # 49 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Patience55 - 24 November 2012 06:03 PM
Anything above 4GB’s really makes little difference to Bryce since Bryce without the LAA tool can only access 2GB’s and with the LAA tool approx. 3.5GB’s. Now if all one had was 4GB’s then more memory might still be helpful if one was planning on running a bunch of other programs at the same time as when they were running Bryce. Since the OP has 8GB’s already I doubt jumping up to 16GB’s is going to make that much difference. Typically people who actually need that much memory are more intimately aware of what adding hardware can do for them and as such aren’t likely to be asking the kinds of questions the OP did.
Profile
Posted: 25 November 2012 02:53 AM   [ Ignore ]   [ # 50 ]
Member
Avatar
Rank
Joined  2009-10-02
I have make a test.
I have bought from a friend a small (64 GB) SSD drive and have the Windows installed on it. As you can see in the screenshot, the window power index is now higher than before (5,9—> 7,2). Windows starts very fast (ca. 10 seconds). Other programs start now even faster, with one exception: Bryce. On render times, nothing has changed.
Image Attachments
Profile
Posted: 25 November 2012 10:12 AM   [ Ignore ]   [ # 51 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Roland4 - 25 November 2012 02:53 AM
I have make a test.
I believe that is due to the fact that everything in Bryce is done in memory. If so then the only way to speed up bryce would be if your memory wasn’t the fastest your system supports and you replace it with the fastest memory your system supports or you build a faster system.
Profile
Posted: 25 November 2012 01:30 PM   [ Ignore ]   [ # 52 ]
Addict
Avatar
RankRankRankRank
Joined  2012-04-07
LordHardDriven - 24 November 2012 06:14 PM
wink I am the OP. Thread has gone off abit. Others are inquiring in here as well, which is fine by me.
 Signature
Profile
Posted: 27 November 2012 02:17 PM   [ Ignore ]   [ # 53 ]
Member
Avatar
Rank
Joined  2009-10-02
Now i have upgradet my system with 16 GB RAM and a 240 GB SSD drive. The performance index from my system you can see in the picture. As you can see, the SSD drive is with 7,9 the strongest component in my system, the RAM the next. Render times have changed nowhere. The workflow is now everywhere great. The SSD ist from OCZ.
Image Attachments
Profile
Posted: 27 November 2012 05:33 PM   [ Ignore ]   [ # 54 ]
Member
Rank
Joined  2010-12-21
Might be an interesting experiment, if you have masses of RAM, to try running multiple Bryce Lightening render sessions in Windows as Virtual Machines ... the outcome really will depend on if the rendering on your PC is RAM limited or CPU limited.  You can expect to see a 5-10% hit on performance per VM due to the virtualisation overhead, but if you have 8Gb upwards of RAM then the effective doubling of CPU utilisation may net an overall 50-80% gain in overal rendering speed if you have a powerful enough CPU and memory bandwidth.
Profile
Posted: 27 November 2012 06:41 PM   [ Ignore ]   [ # 55 ]
Member
Avatar
Rank
Joined  2003-10-09
Roland4 - 27 November 2012 02:17 PM
That’s a fine system, and although the larger RAM and SSD will not improve Bryce render speeds they will bring great benefit to your computing experience overall.
Without making big changes to hardware (motherboard, CPU, RAM) your remaining method of improving Bryce render speed is to overclock your CPU (and maybe your motherboard and RAM too, depending on which method used). And the 2500K is a superb overclocker (much better than the 3770K). The only hardware you will need is a good CPU cooler. Other than that you need research and caution.
The web is loaded with information on overclocking the 2500K, and you can take your time to learn before even considering the idea. A moderate overclock of this chip is very safe and will bring a worthwhile render speed improvement, for little cost.
Profile
Posted: 27 November 2012 07:37 PM   [ Ignore ]   [ # 56 ]
Member
Rank
Joined  2010-12-21
I see Patience has ordered a machine now, but maybe also worth reading this earlier thread:
http://www.daz3d.com/forums/viewthread/6942/
Separately, thinking “bang for bucks” and purpose ... if one has a good solid fast machine as a workstation then what might one do to improve render performance.  With Bryce’s memory limits, the answer is probably not to buy a modern pricey CPU with very large addressing, but maybe instead smaller machines using much cheaper N-1 technology CPUs.  Doing a quick Google for bargain PCs, I found loads with decent CPUs, 4Gb RAM and cheap as chips prices so much that one could get 3 of them for the price of a decent modern desktop, e.g.
http://www.computerbargains.co.uk/shop/catalog/category_255_Desktop_PCs_page_1.html
Throw a cheap multiport KVM switch in the price and you don’t even need to get more keyboards or screens.
Profile
Posted: 28 November 2012 09:47 AM   [ Ignore ]   [ # 57 ]
Member
Avatar
Rank
Joined  2009-10-02
_ PJF _ - 27 November 2012 06:41 PM
Thank you very much for this tip, but i dont want overclock my CPU or other components. I love my new PC and it took a long time until I could buy a new and modern computer, because my dog was very sick and has cost me a fortune (3000 € (i love my dog)) and I do not know what else is everything coming. I am now very happy with my new computer.
Profile
Posted: 28 November 2012 09:50 AM   [ Ignore ]   [ # 58 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
Roland4 - 28 November 2012 09:47 AM
And this is really the only thing that matters.
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 28 November 2012 10:38 AM   [ Ignore ]   [ # 59 ]
Member
Avatar
Rank
Joined  2009-10-02
Horo - 28 November 2012 09:50 AM
Sure, because before I had one of the slowest computer. Q 8300, nvidia 7300 and 2 GB DDR 2 800 RAM-memory.
Profile
Posted: 28 November 2012 04:42 PM   [ Ignore ]   [ # 60 ]
Member
Avatar
Rank
Joined  2003-10-09
That’s a perfectly reasonable and sensible approach for a prized possession bought at considerable cost.
Still, overclocking might be worth considering in a couple of years when the computer is less modern and less valuable. It will boost the system closer to the performance of the mainstream CPUs of 2014/15, and be much less financially risky.
...before I had one of the slowest computer. Q 8300, nvidia 7300 and 2 GB DDR 2 800 RAM-memory.
Your old, slow computer had a faster processor than my current machine with its Q6600. On the rare occasions when I can give Bryce a good workout, I just overclock the system to deal with long renders. Upping the speed from 2.4Ghz to a moderate 3.2 Ghz gives a Windows result as shown in the March 2010 screen capture below. Not too bad for free, and enough for my light use nowadays.
It is good to be in a happy computing and Bryceing place. To keep yourself there, don’t forget to backup your files!
And many happy walks with your doggie. :-)
Image Attachments
Profile
4 of 5
4
