Digital Art Zone
I have a Poser - What is the Value of a PNU
Posted: 15 September 2012 08:31 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2010-03-14
Hello DAZ 3D Community,
Now that Mattymanx has done a little Poser work for me I need the answer to a Puzzler.
What is the Value of a Poser Numerical Unit.
I have seen 8ft, 8.6ft, 103.2 inches, one unit so many definitions.
So does anyone official know the answer to this.
Haslor
 Signature
Metadata has a Standard, so please us it!
Creation Instruction coming soon to a Document Center Near you.
Warning: Sitting for more than 6 hours a day is not good for you.
So Stand up, change you desk to a Stand up Desk.
Walking is good for you, so get up and walk for at least a half hour a day.
Profile
Posted: 15 September 2012 09:03 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
If you have Poser, you can load the cube and then go to the props library and there should be a + button for you to add it to your library.
If you do not have Poser I will do that for you.
There is also a method to do it in DAZ Studio using a plugin - PP2 Exporter: http://www.mediafire.com/?3m5gbz5f8bjjgjm
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Ships of the Line - MEGA THREAD
How to use the Poser Format Exporter - **Updated 2013-02-09**
Profile
Posted: 15 September 2012 09:06 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2010-03-14
THIS IS Request was completed by Mattymanx,
Thank you for you assistance.
Haslor
The original Post, Moved here to free up the Top Spot:
I have a Favor to ask of a Poser User.
Don’t worry it is very Simple.
I want to send you a Cube.obj and I would like you to make it into a Prop.
I want you to use the same process you would use for any OBJ imported from a 3D Modeler like Blender or Modo.
The Cube I will Send you was Created in Hexagon exported as a OBJ file, Imported into Blender and then exported again as a OBJ.
The Cube is perfect cube and it should load on the floor.
Again all I would like you to do is Import it, and Export it as a PP2 file, which would be loadable in any current version of Poser or Studio.
There is no texture with the cube, it is just the Cube.
MAC OS reports the file is only 795 bytes.
If you want to do this, respond here and then I’ll PM you so I can send you the Cube.obj.
I am thinking this is a fifteen minute task, but seeing I’ve never made a Poser Prop I’m not sure how long it will take.
Thanks in Advance
Haslor
 Signature
Profile
