Digital Art Zone
Suddenly… black renders!
Posted: 14 September 2012 04:59 PM   [ Ignore ]
Member
Rank
Joined  2012-07-20
Hello…
I didn’t find any threads here that echo my issue exactly, so I’ll have to ask.
My renders have been beautiful and trouble free til today.  Now, for some unknown reason, my renders are basically black!  It seems to render fine once, and then the issue arises after I save the file and render again.  These are spot renders, by the way.
Any help will be appreciated, as I’d rather not have to reinstall.  Very strange…
Thank you!  :(
Profile
Posted: 14 September 2012 05:12 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
What version of DS are you using, and what object are you spot-rendering?  Can you turn smoothing off on it and see if the problem goes away?
 Signature
My store at DAZ.
My Deviantart gallery.
Profile
Posted: 14 September 2012 05:40 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Have you tried looking at the log file? (version of DS and will tell you how to get there)
I’ve seen it happen sometimes when the 3Delight render ‘hangs’ and doesn’t stop for some reason, before you try to do another render.  Usually exiting DS and restarting will fix the problem, sometimes a reboot is needed.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 14 September 2012 06:38 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2012-07-20
Guys, I’m using 4.  And you may be right…
My other computer’s video card died, so I had to go and get a new lappy.  While I was doing that, it occurred to me that the two scenes I was having the issue with are related… one is a slightly re-posed version of the first, but the camera and lights are the same.  So I thought I’d come home and re-save one or both with a different name, and start killing lights to see if I could find the culprit.  Meanwhile I had rebooted the computer, as well as the external drive that I run my content from (works great, btw!).  But, lo and behold, all seems to have cleared up as far as I can tell.  Still testing… but maybe 3D-Light burped or something?  Hope that’s all it was.
Btw, Sickle, I use some of your freebies, and they are FUN!  :D Thank you!
Fingers crossed, guys.  Thanks for the support!
Profile
Posted: 14 September 2012 06:42 PM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
You’re welcome on both counts.  Here’s hoping everything keeps working. grin
 Signature
My store at DAZ.
Profile
Posted: 14 September 2012 07:07 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2012-07-20
Well, it was dfoing it on the one scene again, but I removed one light at a time and it seems to have been Spotlight 1 that was upsetting the cart.  I deleted it and re-lit, and it’s rendering again.  Very strange!  At least I know something’s not globally effed up!
Profile
Posted: 14 September 2012 07:15 PM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
There’s a View Log under the Help button…if you look at the log, I’m going to take a guess that there will be an error relating to that spotlight.
 Signature
1432 old posts
My ShareCG gallery.
Profile
