Digital Art Zone
Background map!
Posted: 28 May 2012 04:13 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-09-22
I got a nagging issue in HEX! I have a background set up. NOT IN or on the BACKGROUND Proper but on object so I can model my f-4 corectly! The OBJECT started out as one big object that I assigned the BLUEPRINTS to then CHOPPED it up and use it like seen here. AND it work great.
But everytime I reopen it I have to FLIP the image to set it back right! SEE IMAGE!
Whats up with that! I set the original correctly
Image Attachments
Profile
Posted: 28 May 2012 07:50 PM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2009-01-27
Known bug.
DAZ might not think it’s a bug, but IT’S A BUG!!!  grin
The only workaround I found was obvious but irritating: Flip your texture files in an image editor so that they’re upside down - then hex will flip them rightside up when it loads them.
 Signature
For any arguments or illustrations I give, my system specs are:
Hexagon version 2.5.1.79,  XP pro 32 bit,  pentium core2 duo,  ATI radeon 3870, 2 gigs ram
Profile
Posted: 28 May 2012 08:56 PM   [ Ignore ]   [ # 2 ]
Addict
RankRankRankRank
Joined  2004-07-21
afreaginname - 28 May 2012 07:50 PM
Known bug.
Sounds very irritating.
 Signature
Hello, Sweetie!
Profile
Posted: 28 May 2012 11:08 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2003-11-09
off-topic, b ut where did you get the nice 3-view of the double ugly?
also, just a hint, you may want to try out the gordon surface tool - it greatly simplifies the shape of the fuselage and even the wings….
 Signature
Profile
Posted: 29 May 2012 03:35 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2012-04-28
You can find some really cool blue prints and vectors here:
http://www.the-blueprints.com/
 Signature
~ Roy
I’m so confused!
Profile
Posted: 01 June 2012 06:55 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
hiker_1 - 28 May 2012 11:08 PM
HUM I will give that a try! I have just always gone basically poly by poly. I may restart and try that the more I think of it. AS far as the Blueprints I found the best resource I have found even better than that BLUE-PRINT site and its free! OF course its form RUSSIA! Go figure its
http://www.airwar.ru/
Its all in russian and you have to guess at what your aircraft is but its the best site i have found yet! The only issue I have is that at least with the one o used here for the UGKY f-4 is that the CROSS SECTIONS didn’t quite match up to the side, top, and front views. But they were a great guids
Profile
Posted: 01 June 2012 06:58 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
ALso a hard issue to consider while thinking of how to set the F4 up is the Air intakes! sort of in the middle its attached to the main body but then separates
Profile
Posted: 04 June 2012 05:27 AM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2009-09-16
When you uvmap the plane that the image is to be placed onto there is a option to swap uv’s there which will get your texture the right way up and it will stay that way.
The option to flip texture horizontally or vertically in the material settings is bugged.
Profile
Posted: 04 June 2012 09:19 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
Hey I am aware of the bugs but I still think for the money Hexagon In my opinion is a first class modeler! I will never use but of a fraction of what it is capable of! I have had Lightwave 8 for 5 years now and never even open it any longer! I did some simple Modeling work in it and it felt like I was signing a check with my wrong hand.
Also any TUTORIAL your gunna a see like on youtube in any modeler such as MAYA translates over into Hex very easily!
Profile
