Digital Art Zone
1 of 2
1
The Moon
Posted: 14 September 2012 06:04 AM   [ Ignore ]
Power Member
Avatar
RankRankRank
Joined  2007-12-10
I discussion about the Moon recently prompted me to have another look at how you can create a Moon instead of using the Bryce default Moon (which as I’ve recently found out, you can not alter the brightness of).
For this tutorial, we are going to use the moon found here in Wikipedia: Download this picture to your hard drive
This is a good one to use because it doesn’t need any any work in a photo editor, it will just load as is into Bryce.
Picture 1: So we create a document, delete the ground plane and add a 2D round plane
Picture 2: Set up a suitable background. I’m using the plain Starfield
Picture 3: Select the 2D round plane and click on the ‘M’ button in it’s mini menu to take you into the Material editor.
A; Click in channel A in the Diffuse row to create a ‘dot’, the A channel nano preview now opens.
[note: ignore the fact mine has already got a moon in it, if yours is the very latest version of Bryce, yours wont have. I’m having to do this in a slightly older version because I am on a Mac and getting pictures into the ME in the latest version doesn’t work).
B; Click the little button with a ‘P’ on it (at this point the latest version of Bryce will load the DaVinci man picture)
C; Click the button directly above it to take you to the picture loading window
Picture 4: Again ignoring that mine has got a Moon in there already, you need to click one of the blank squares in the bottom on this window.
Picture 5:
Navigate to the place on your hard drive where you saved the Moon picture you downloaded, select the picture and click the ‘open’ button.
More to follow as we can only attach 5 pictures at one time. smile
Image Attachments
 Signature
I’ve got nothing of my own to promote, no models, no tutorials, no website, nothin’, nada, nill, nowt.
Profile
Posted: 14 September 2012 06:35 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-10
Picture 6: So now we have the picture loaded into the first square, we need to click the ‘copy’ button underneath it and paste the image into the second square. When you click the ‘paste’ button under the second the square you will be asked if you wish to delete the image.
Don’t be fooled into thinking you’re deleting your moon image, this will only clear the blank square and replace it with your copied moon image.
Picture 7: Now you have the moon in the first two squares and we’re good to go back to the main ME window so click the tick at bottom right.
Picture 8:
The mapping mode we are going to use is ‘Object Cubic’ (don’t ask me why, I’ve no idea, but it works) Access this menue by clicking on the little button with the down arrow at bottom right of the nano preview box.
Picture 9: Let’s look at our picture of the Moon in the main viewport. For illustrative purposes, I have created a grey background so we can better see that the Moon doesn’t fit exactly, the picture is too small and the black boarder of the photo is showing.
Picture 10: Go back into the Material Editor and click the button at top left in the texture/picture preview box (which I’ve highlighted with a small red circle), this will open up the texture/picture transformation tools which will allow us resize and if necessary reposition the picture on the 2D plane.
The resize control is the top set of controls (which I’ve highlighted with a large red circle). You can either place your mouse in the center of this control and drag to resize in proportion (it will go up or down in increments of 1 Bryce Unit, of if you perform the same task with the shift key pressed, it will go up or down in increments of 0.1 Bryce Units), or click in the numerical readout and type in the number you want.
In this instance the Moon picture we’re using needs to be set to -1 for the top set of X, Y and Z.
More to follow, but we’re nearly done. smile
Image Attachments
 Signature
Profile
Posted: 14 September 2012 06:58 AM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-10
Picture 11: So we’ve got out Moon resized on the 2D plane to -1 on X,Y, and Z.
Picture 12:
Checking a quick render, we can now see that the black has gone from the edge and the face of the Moon fills the 2D round plane nicely.
Picture 13: We now need to light the Moon up a bit, so create a radial light and set it infront of the 2D plane (how far away you set it is up to you, mine is about the same distance away as the 2D plane is wide). Then click the little ‘E’ button to enter the Light Lab.
Picture 14:
Using the Light Lab to brighten/darken, change the colour of the light and set what this light influences.
A: In my picture I tried a few diffuse settings until it looked right, mine is set to 31 (I didn’t edit the specular, that’s at it’s default).
B: In some scenes a blueish Moon looks good, in others it needs to be a bit yellowy, use this colour palette to choose a colour.
Bearing in mind that the brighter you set the diffuse and specular, the more washed out this colour will look.
C: Lastly, if we set the influence to only include the 2D plane, this will make sure that our ‘fake’ Moon will not affect the lighting set up in our scene and cause shadows that will look wrong or reflections in the wrong place.
Picture 15: Now our moon is lit, we can see it looks brighter and slightly bluish around the edges. and it’s ready to go into the scene.
Image Attachments
 Signature
Profile
Posted: 14 September 2012 07:24 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-10
Here is the same Moon placed over the Bryce moon in my Canyon at night render.
I did alter the lighting bit to match the new Moon better.
Image Attachments
 Signature
Profile
Posted: 14 September 2012 12:54 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2011-09-25
Thanks for the tutorial, The Savage.  Now that canyon looks as it should.  Nice job.
 Signature
If you constantly look backward, it’s guaranteed you’ll run into something on your forward journey.
Profile
Posted: 14 September 2012 04:52 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2009-07-07
G"day TheSavage64
Here is what I have achieved so far following your directions, I already had a moon image so I used that one, I managed to get the full moon, and saved it in the library for further use,  (just need to work on the lighting now.
But I had a play with making a crescent moon, I just duplicated what I had, bought it a 4d circle plane and positioned it, went into the material editor changed the disc to black to blend in and then rendered, but I noticed an absence of stars, so I thought I would go into the material editor again and add a starfield to the disc,, but when I rendered it the disc became invisible, so I then tried adding a starfield image to the disc and the same thing happened,
is this a bug?
Image Attachments
Profile
Posted: 14 September 2012 06:59 PM   [ Ignore ]   [ # 6 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-10
I don’t think it’s a bug.
When you add a star field to a solid, what you are in effect doing is creating an alpha channel with some specular dots in it.
And of course, the alpha channel make things transparent. smile
So for the crescent Moon, Booleans are your friend.
Select your 2D disc and go into the attributes window (that’s the little ‘A’ button in it’s mini menu).
Across the top you will see some selection check boxes. you need to select ‘Positive’
Then create a cylinder that is just a bit bigger in diameter than the disc and only a few Bryce Units deep.
Go into the attributes of the cylinder and check the ‘Negative’ box.
Making sure the cylinder is cutting through the disc, select them both and group them.
You will then see that the cylinder has created a cut out from the disc (see picture below).
For different phases of the Moon, you’d alter your cylinder accordingly.
Problems: The main problem with this is if you have stars in the vicinity of the Moon, you don’t want them showing up inside the area that has been cut out (because in reality, the Moon is still there, you just can’t see it in the night sky). If that happens you can alter the amount of stars in the Sky Lab until it gives you a pattern that doesn’t have any stars too close to the Moon.
Image Attachments
 Signature
Profile
Posted: 26 November 2012 08:18 PM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2012-01-03
Working on my first full scene in bryce. I still have some tweeking to do in the DTE as it is still mostly guess and render for me still. But I am wanting to add an alien moon/planet behind the clouds, can I do this in bryce or do I need to do a separate render and photoshop them together?
Image Attachments
Profile
Posted: 27 November 2012 02:53 AM   [ Ignore ]   [ # 8 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
nreed - 26 November 2012 08:18 PM
If the clouds in your scene are the clouds generated by the sky lab then you are limited as to how you can get a moon/planet behind them.  The first and most obvious is the Bryce moon - but obviously that’s not a very interesting answer - or you can load a HDRI image with a planet on it and put that behind the clouds.
However, if you turn off the clouds in the Bryce sky lab and introduce your own cloud layer, either using an infinite plane with a cloud material applied, an infinite slab with a volume cloud or produce your own clouds using spheres and volumetric materials.  There’s a lot of scope here for experimentation.  Then you can place your moon/planet up above the clouds without any problem.
Image Attachments
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 27 November 2012 06:01 AM   [ Ignore ]   [ # 9 ]
Member
Avatar
Rank
Joined  2008-11-17
My recent image with moon done in Bryce. You can compare the look with and without the additional moon. The moon is a sphere with material as shown below. And a finished image after some postpro.
Image Attachments
Profile
Posted: 27 November 2012 10:34 AM   [ Ignore ]   [ # 10 ]
Member
Avatar
Rank
Joined  2012-01-03
Thanks for the moon pic they give me a good idea of what I want to do…
David thanks for the information…. I guess I will have to jump ahead on the dvd to clouds then…:-) though I know I will be replaying the DTE tuts again….
Profile
Posted: 27 November 2012 05:11 PM   [ Ignore ]   [ # 11 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-10
Also, let’s not forget that the default Bryce moon can be changed to any image from the moon options in the skylab and it will appear behind the clouds.
Here for instance is a quick scene I just put together where the standard Bryce moon has been substituted for an image of Jupiter.
Image Attachments
 Signature
Profile
Posted: 27 November 2012 11:05 PM   [ Ignore ]   [ # 12 ]
Member
Avatar
Rank
Joined  2012-01-03
Well I didn’t have tome to go through the tuts on clouds yet but from your last posts I gleaned enough to throw it together…the mats are just temp I will be working on those….Is there a way to not have the sun effect just the moons so I can use my own lights? I tried adding a light to give some shadow but to no effect…
Image Attachments
Profile
Posted: 28 November 2012 12:43 AM   [ Ignore ]   [ # 13 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-10
nreed - 27 November 2012 11:05 PM
Yes, you can switch the sun off completely in the Sky Lab.
Access the sky lab by clicking on the little cloud icon that appears when you’re on the ‘sky & fog’ tab.
Then down the right of the window that opens up (where the nano preview shows and the control for the sun position is, you will see a radio button to disable the sun. Click it and the sun will go out. You can then use your own light setup to light your scene.
Other things to bear in mind; Make sure the global shadows are set to 100 (the default for most skies seems to be 90) and adding multiple lights to light up volumetric materials will increase render times drastically.
You may also need to use the ‘influence’ option in your lights if you get shadows casting on the plane you’ve put the clouds on.
If it’s a problem make sure you exclude the cloud plane from the lights influence (you can always add another light who’s influence is set to only include that cloud plane if it needs brightening up).
 Signature
Profile
Posted: 30 November 2012 07:48 PM   [ Ignore ]   [ # 14 ]
Member
Avatar
Rank
Joined  2012-01-03
Well I got my moon(s)  looking more like what I wanted. With the big one I added a cloud layer that I was not able to get as transparent as I would have liked, but it turned out ok for me, for now… First time playing with the infinite cloud plane and I got it mostly the way I wanted but I sould like to have made it look like there was more movement. LIghting is still a puzzle for me but I hope to be able to get through some tuts on bryce lights so I can get it the way I want…
Opinions and sugestions welcom, mostly about he moons I guess as that is the topic on this thread.. grin
Image Attachments
Profile
Posted: 03 December 2012 09:14 PM   [ Ignore ]   [ # 15 ]
Member
Rank
Joined  2003-10-23
TheSavage64 - 14 September 2012 06:59 PM
  snip
snip
I think the boolean cut or completely hiding part of the moon to get a crescent seems inadequate and looks fakey because in real life the dark part of the crescent is not “cut” away but darker and not completely evenly darker…take a good close look.  Best accurate solution would be to cast a dark shadow onto a 3D moon…to simulate the real physics.
Profile
1 of 2
1
