Digital Art Zone
Strange, but not serious, error message from Hexagon
Posted: 13 September 2012 07:10 AM   [ Ignore ]
New Member
Joined  2007-07-27
I occasionally get the following strange Error Message from Hexagon:
“Can’t load image from file ‘E\3D\buste\buste.jpg’: file does not exist.”
Dismissing the Error doesn’t cause any problems so it doesn’t matter but it is odd.
I’ve never used a placed image in Hexagon or ever had a JPG called “buste.jpg” on my hard disk.
I can always reproduce the Error if I start with a new file and then drag any primitive into into the work area and then delete it. The error message pops up every time.
This happens at work with a Mac running Leopard or at home with my Mac running Mountain Lion.
Profile
Posted: 13 September 2012 10:27 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
That is an old error from way back.  If you use a reference image in the background Hex remembers that every time you open a new scene and wants to load it.  Best way to get rid of it is to set the grid to default.
Possibly at some stage you downloaded a file from somewhere that had that image as a reference and the author didn’t reset the grid to default before exporting it?
Profile
Posted: 18 September 2012 05:36 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2007-07-27
Roygee - 13 September 2012 10:27 AM
Thanks for that. I still don’t know where the file name came from but setting the grid to default has cured the problem.
Profile
Posted: 18 September 2012 06:25 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Glad it worked - Hex can get up to some funny tricks!
Profile
Posted: 18 September 2012 07:12 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2005-08-20
Have you recently opened a downloaded .hxn file in Hexagon?
 Signature
*Sigh* Window->Tabs->Tool Settings->Draw Style->Manipulation: Off
Yeah. It’s like that.
Profile
Posted: 19 September 2012 02:41 AM   [ Ignore ]   [ # 5 ]
New Member
Joined  2007-07-27
Ascania - 18 September 2012 07:12 AM
Thanks for the clue.
When you instal Hexagon there are some sample files in a folder called “Models” inside a “Content” folder that installs as well. I opened one called “Alien Face” and the mysterious file name loads with it.
I opened the same file on Macs at home and at work so that’s why I was getting the same error on different Macs.
Mystery solved!
Profile
Posted: 19 September 2012 12:34 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2009-01-27
Jon-3D - 19 September 2012 02:41 AM
Mystery solved!
For YOU, maybe…  smile
But for me, it just uncovered one!  mad
And, once again…“strange”.
I checked my “content\models\character” directory as you described just to see what you were talking about.
I opened “alien_face.hxn” - and crashed.  oh oh
I tried another model and then another, and all crashed on the same module: frameworkdll.dll
I then went into all the other subdirectories under models, opening 2 or 3 in each one without any problems.
I returned to the “characters” directory and tried every single model, and every single one crashed on frameworkdll.dll (Checking my dot net versions, I see I have 2.0, 3.0 and 3.5 installed - should be okay)
I then did a content search on all files in all subdirectories under the “models” directory for files containing the string “jpg”
ALL the files, and ONLY those files, in the “characters” directory showed up.
All but 2 had the string “E:\3D\buste\buste.jpg” in them. The remaining two (quadrangulator and teteronde) referenced “C:\Mes documents\Eovia\envoi\wallpaper17.jpg”
I even created those directories and stuck a moxnix jpg in them renamed according to the strings above. Then I retried opening the files but they still crashed.
Not all is lost, though - I’ve never looked through that directory until now. There’s a lot of pretty cheesy crap in there, but a few of them looked interesting for later perusal.
And to Ascania: KUDOS!!! That was a very intuitive suggestion you gave that turned out to be dead on!  smile
 Signature
For any arguments or illustrations I give, my system specs are:
Hexagon version 2.5.1.79,  XP pro 32 bit,  pentium core2 duo,  ATI radeon 3870, 2 gigs ram
Profile
