Digital Art Zone
Spacebar = Play Stop? is it possible
Posted: 12 September 2012 05:36 PM   [ Ignore ]
Member
Rank
Joined  2011-11-01
Hey everybody
Most of other programs I use ( Pro Tools, Sony Vegas ) use spacebar to play or stop.
It is a habit I can’t seem to break.
Is there a way to set that in Carrara. I looked at the shortcut Keys and didn’t see one for Play ( timeline animation )
Thanks in advance.
8068
Profile
Posted: 14 September 2012 05:07 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI 8068 smile
No, not as far as I can see,.. there’s no short-cut for (Animation / Play/Stop)
The space-bar is set up as the default short-cut for Pan.
smile
Profile
Posted: 06 October 2012 09:40 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-05-06
I don’t know if this would be helpful in Carrara but in Daz Sudio 3D you can designate a button for Play/Pause.
Go to “Edit > Customize”. Click on the dropdown for “aniMate2 (4th from top)” Right-click on Play/Pause and select “Change Keyboard Shortcut” from the drop down menu. From there simply press/select the button on your keyboard you would like to be the hot key, click Accept then Apply. Thats it. Hope this was helpful.
Profile
