D|S 4.5 GenX fails to load... do I need a new version?
I have GenX for 4.0, but for D|S 4.5 it fails. Do I need a new version of GenX?
Too, is there anything new in the Genesis pack that comes with D|S 4.5 that didn't come with 4.0?
I think Zev0 said that the new installer is up for GenX so reset your downloads.
Coolness!!! Thank you very much!
Yep, it is there! Thank you again!
I see the various GenX installers have a version 1.0.0.1 and a version 1.2.0.0 . Am I correct in assuming the 1.0.0.1 is old and should not be used, or is 1.2.0.0 an upgrade and I should be installing both?
The answer depends upon what version of Daz Studio you are using. If you are using Daz Studio 4.5, you should use GenX 1.2.0.0. If you are using Daz Studio 4.0, then you should use GenX 1.1.0.0. I believe the GenX versions are specific for the version of Daz Studio listed and will not work if you cross them. As for GenX 1.0.0.1, I do not know as I am not familiar with this version.
thanks!
