Digital Art Zone
1 of 2
1
DAZ Viewport - Turn off Oppacity Maps?
Posted: 12 September 2012 12:37 AM   [ Ignore ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Is there a way to turn off oppacity maps in Daz view port? I’m trying to set up a forrest/jungle render scene, but the trans maps in the viewport are causeing very serious lag! I want the oppacity to still work in the actual render, but not to appear in the viewport.
Can anyone help?
Thanks
 Signature
I’m not Spyro the dragon… We just look alike! tongue wink
“Anything in the real world can exist in 3D”
Eyeshine Tutorial for Daz3D vampire
- - My Render Thread - - My Deviant Art - -
- - xSPYROx ShareCG Freebies - -
Profile
Posted: 12 September 2012 01:17 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2009-08-05
You can create a shader that turns them on and off. Basically you create one to disable and one to enable. Have a look at this thread.
http://www.daz3d.com/forums/viewthread/7397/
 Signature
My Daz Store
My Rendo Store
Latest Products
FaceWeight for Genesis
Toe Control for Genesis
Profile
Posted: 12 September 2012 01:35 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Thanks Zev! I’m having a read. Atm, I worked out it was softer on the computer to hide trees that ive already placed, as well as characters. Just means the new trees placement is a bit of a guess… But I’m working in ‘zones’ on the scene, to avoid double placeing items.
Thanks again smile
 Signature
Profile
Posted: 12 September 2012 01:44 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2009-08-05
What I do more now is change my viewport to smooth shaded while constructing a scene and just switch back to texture shaded when I need to see details.
 Signature
My Daz Store
My Rendo Store
Latest Products
Profile
Posted: 12 September 2012 01:51 AM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
I find that anytime I am working with a large scene, it is easier to split it up into parts then it is to have it all loaded at the same time.
In this case having the forest as its own scene and each fully dressed character as their own individual scene.
If you need to place and pose a character after you built your forest then you would load the forest in after the character and then remove all that you do not need.  So you would end up with the forest floor and maybe a few trees in the scene with the character and then when the pose and placement is complete, remove anything not related to the character and save the scene.
What this does in the end is it makes dealing with each character or element faster and thus easier since the load and save times will be a lot faster and of course your computer can handle what your doing a lot better too.  Also if you need to go back and make a minor tweak on one character you dont have to load everything else too.
When it comes time to render, just load the first one and merge the rest.  Just make sure you save your desired camera angle in one of the scenes too along with your lighting!
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Ships of the Line - MEGA THREAD
How to use the Poser Format Exporter - **Updated 2013-02-09**
Profile
Posted: 12 September 2012 02:02 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2007-08-17
Zev0 - 12 September 2012 01:44 AM
This is what I do too - as long it’s the textures and transparency maps and not the polycount that are slowing things down. Even in case of high polycount changing temporarily to solid bounding box for moving objects and camera helps a lot.
 Signature
My DAZ3D store
My Facebook page
Profile
Posted: 12 September 2012 02:22 AM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Thanks guys! I’ve began to recreate the scene in parts, Characters will have their own, the forrest will be broken up into sectors and lighting will come into play with appropriate light obstructions matching all of the separate scenes. I may render the character one separately and layer them into the final render (Shadows and Lighting matched of course). I’ll try out the smooth shaded as well.
Thanks everyone! cheese
 Signature
Profile
Posted: 12 September 2012 02:53 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
A little lighting/surface tweaking tip:
If the surfaces look good under day time lighting then they should look good under most any lighting.
at least thats the theory.
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Profile
Posted: 12 September 2012 09:26 AM   [ Ignore ]   [ # 8 ]
Power Member
RankRankRank
Joined  2011-11-16
Mattymanx - 12 September 2012 01:51 AM
I find that anytime I am working with a large scene, it is easier to split it up into parts then it is to have it all loaded at the same time….When it comes time to render, just load the first one and merge the rest.
If you have different parts to the scene that don’t interact directly with lighting such as background elements and foreground elements, the scene can even be rendered in parts and merged together in a 2D program afterwards. This allows re-rendering a much smaller project if only an area needs to be tweaked. In this case, make sure the overall lighting is the same in background and foreground renders. localized lighting for the foreground only need to be in the foreground render usually.
Dreamlight has some tutorials on an advanced version of this.
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 12 September 2012 11:42 AM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
Gedd - 12 September 2012 09:26 AM
It may be a time saver for small areas but even still, one never knows all that influences an area of the scene so you run the risk of missing elements.  On top of that, the more you have in a scene, the more of a nightmare it is to combine it to look as though it was never split up.  DS is more then capable of rending it all together.
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Profile
Posted: 12 September 2012 11:52 AM   [ Ignore ]   [ # 10 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Changing your viewport to smooth shaded instead of texture shaded helps alot too.
 Signature
My Tutorials and Freebies Index
Profile
Posted: 12 September 2012 12:04 PM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Thanks guys heaps… I got it running alot smoother now, even to the point where I can actually load characters to the jungle set. The smooth shaded view was very helpful, I did break up the set, and it all fits together nicely smile Thanks very much for all your help!! cheese
 Signature
Profile
Posted: 12 September 2012 05:06 PM   [ Ignore ]   [ # 12 ]
Addict
Avatar
RankRankRankRank
Joined  2011-10-04
adamr001 - 12 September 2012 11:52 AM
Daft question—how do I do this?
 Signature
Thanking: M F M for a gift of dragons!
My DeviantArt page.
My DAZ Studio 4 freebies.
Profile
Posted: 12 September 2012 05:18 PM   [ Ignore ]   [ # 13 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
little round moon looking ball with down arrow under it it the right hand of the viewport, for me.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 12 September 2012 05:23 PM   [ Ignore ]   [ # 14 ]
Addict
Avatar
RankRankRankRank
Joined  2011-10-04
Thanks. Now, does anyone know how to get back mouse pointer that just vanishes without any explanation whatsoever?
 Signature
My DeviantArt page.
Profile
Posted: 12 September 2012 05:29 PM   [ Ignore ]   [ # 15 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Skiriki - 12 September 2012 05:23 PM
Nope, Not I, never had that happen but once. I did have the kitty cat semi-virus once, really a joke app, a kitten would pop on screen and chase your pointer down and eat it, took a reboot to get it back, standard uninstall cure it.
 Signature
Profile
1 of 2
1
