Digital Art Zone
Cell shaded stuff
Posted: 11 September 2012 09:45 AM   [ Ignore ]
Member
Rank
Joined  2012-01-29
I downloaded pwtoon and have been trying to get cell shaded stuff work by watching the tutorial in deviant art
But i am not able to at all get the desired result. I dont know what wrong i am doing
Do any1 have any better tutorials or can you highlights the steps needed for it
Also is it necessary to use aiko for cell shaded stuff or genisis will do
Profile
Posted: 11 September 2012 12:08 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Any figure will do. How is it failing? If you use the Surface selection tool to click on part of Genesis, what shader is listed at the top of th Surfaces pane?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 13 September 2012 01:19 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2012-01-29
Its Daz studio default
Profile
Posted: 13 September 2012 01:24 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
OK, in that case you haven’t applied the shader successfully. Do you have the updated versions of pwToon for DS4.5? Are you applying the base shader or an effects preset, and are you remembering to seelct surfaces before applying the preset?
 Signature
Profile
Posted: 13 September 2012 01:30 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Then you are not loading pwToon, it should say Shader : pwToon at the top of the Surfaces tab.
Please see th image below.  There are three versions of pwToon, one for DS2, DS3 and DS4.  Make sure that you are using the correct one.
Select Genesis in the Scene tab AND in the Surfaces tab before applying the shader.  You will also not see the effect of the shader until you render it.
EDIT:
Another XPost Richard.
Image Attachments
Profile
Posted: 14 September 2012 08:17 AM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2012-01-29
I selected genesis in surface colour editor tab
and i selected genesis in secene tab
Then i went to content libary tab and applied the flesho1 toon but it still says daz studio default in shader
Profile
Posted: 14 September 2012 09:08 AM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
What version of pwToon does the installer say it is.  It was updated recently for DS 4.5 0.114 and it is called 7253_pwToon_1.2_ds.exe, is that the one you have, and what version of DS 4 are you using?
EDIT:
Where are you getting the Flesh 01 toon, I don;t have it as part of pwToon?
Profile
Posted: 14 September 2012 01:13 PM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2012-01-29
Daz is 4.03
Its crescent pwtoon
Profile
Posted: 14 September 2012 01:46 PM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
I don’t have one called Crescent in pwToon resources, where did it come from?  It doesn’t sound like a pwToon shader.  Can you apply any of the other ones to see if they wotk?  You DO know that you wont see any change until you render?
Profile
Posted: 14 September 2012 02:08 PM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2012-01-29
http://cyonixgfx.deviantart.com/art/pwToon-Tutorial-2-DAZ-Gen-3-257227270
I have downloaded it from there long way back.
I can apply orange toon shader and it works
But this1 doesnt
Profile
Posted: 14 September 2012 02:30 PM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
I’m afraid I can’t help you with this, the shader is no longer available it seems.
There is a link here to a help page on pwToon, it might help you:
http://www.poseworks.com/shaders/pwtoon/
Profile
Posted: 15 September 2012 01:14 PM   [ Ignore ]   [ # 11 ]
Member
Avatar
Rank
Joined  2003-10-09
Oh, I remember Crescent’s shaders. I use them all the time! They’re quite good.
omgwtfbbgxy, make sure you have pwToon installed correctly. Crescent’s shaders won’t work unless pwToon (http://www.daz3d.com/shop/pwtoon/) is installed correctly. Try resetting your download from the DAZ Store to get the latest version. It should work well with your version of DAZ Studio.
Once that’s done, as a test, try applying the pwToon shader that came with your DAZ download directly to the surfaces you want. If that works, then find Crescent’s shaders in your Content Library and apply the ones you’d like to use.
Hopefully that helps…
Profile
Posted: 18 December 2012 10:14 PM   [ Ignore ]   [ # 12 ]
New Member
Joined  2011-11-29
Hey,
I recently picked up PwToon 1.2, I’m going to try my luck with it out of the box, but like omgwtfbbgxy I am also interested in using those tutorials as a guide. My problem is much simpler, so far I have had ZERO luck on finding a working download link for those free Crescent PwToon shader presets. Can anyone help me find this? I’ve tried for 2 weeks now.
omgwtfbbgxy how have you made out with the Cel shading renders? I’m hoping to get this process down for use in a game project I’m working on.
Cheers
Br
Profile
Posted: 19 December 2012 04:58 AM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
Try sending a PM to Crescent. That should be her username in the current forum too.
Profile
Posted: 19 December 2012 11:14 AM   [ Ignore ]   [ # 14 ]
Member
Rank
Joined  2010-03-13
breadboxer - 18 December 2012 10:14 PM
Hey,
Cheers
Br
CyonixGFX re-posted the Crescent presets on sendspace, as the readme allows this. The link is among the comments on Deviant. The direct link is:
Crescent’s pwToon Cel Shaders.zip
Profile
Posted: 19 December 2012 02:30 PM   [ Ignore ]   [ # 15 ]
New Member
Joined  2011-11-29
Thank you all for the quick reply!
Renpatsu thanks so much for the link!
I was having so so luck with the pwToon snazzytoon preset with some edits, now I’m excited to give this a try.
Profile
