Digital Art Zone
Model and clothing different colors
Posted: 11 September 2012 08:49 AM   [ Ignore ]
Member
Rank
Joined  2011-12-30
Hi, I am retaking some hexagon videos today and having problem figuring out what is being click to make the genesis model and shirt different colors. Attached picture show show the blue and green shirt with genesis model but on mind it all gray and hard to tell what is what. What am I missing? How do I get the blue and green to show up.
Thanks
Kimberly
Image Attachments
Profile
Posted: 11 September 2012 09:08 PM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2009-01-27
The colors are “materials”, or as hexagon calls them, “shading domains”.
Assuming that the attached image comes from the tutorial video, then it appears that the author has defined the sleeve(s) as one material and colored it/them green, and defined the body as another material and assigned the color blue.
Click the little arrow to the left of your screen to open the materials window and see if your shirt already has materials defined for it and we’ll go from there.
Where did you get the shirt model from?
Image Attachments
 Signature
For any arguments or illustrations I give, my system specs are:
Hexagon version 2.5.1.79,  XP pro 32 bit,  pentium core2 duo,  ATI radeon 3870, 2 gigs ram
Profile
Posted: 12 September 2012 08:48 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2011-12-30
Hi, for this posting I am using this tutor: http://www.daz3d.com/shop/genesis-starter-kit
I found the side window and I found the shader domains.
Thanks
Profile
Posted: 13 September 2012 01:34 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2009-01-27
KimberSue - 12 September 2012 08:48 AM
So you were able to apply colors then?
I ask just to make sure your problem is solved and not leave you hanging in case the answer is no.  smile
 Signature
Profile
Posted: 13 September 2012 02:44 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2005-09-15
Don’t forget to rename either the shading domains and/or the materials.  :0)
 Signature
Cheers, Fanners.raspberry
Profile
