Troubles with "Footsteps" product.
masi3veemasi3vee Posts: 353
Hello!
I hope I'm posting this in the right place. I recently purchased the "Footsteps" product, and though I am able to load round and square fields, as well as their surfaces, whenever I select the surface in Scenes, and then try to load the tool for making footprints, tracks, etc. as described in the ReadMe, DAZ 4 tells me that something in the scene must be selected, even though it is. Anyone aware of a solution? As it stands now, I can't use the product to its full functionality.
Thanks for reading!
  • JaderailJaderail Posts: 0
    Link to the Product. Footsteps is not enough information.
  • wsterdanwsterdan Posts: 1,158
    http://www.daz3d.com/shop/footsteps-tool
    -- Walt Sterdan
  • ChoholeChohole Posts: 27,764
    edited September 2012
    I have a link to a tutorial document included in my download ReadMe's/FootstepsTutorial.htm
    Post edited by Chohole on
  • KeryaKerya Posts: 9,386
    There is this:
    http://docs.daz3d.com/doku.php/artzone/azproduct/8423
    But it is outdated ... the bug in DS3 is fixed, by the way.
  • SimonJMSimonJM Posts: 4,719
    Kerya said:
    There is this:
    But seems to be back in DS4.5
    Hmm... never saw or tried this tool. Looks very interesting. To bad multi tracks are broke again in 4.5.
    Copy of the text in the tutorial.
    The Footsteps tool ...
    The footsteps tool allows you to create realistic tracks in a high resolution plane. The set comes with two large fields designed for this. There is a square and a disk. Both fields include morphs for varied terrain and a second layer to limit the depth of the prints. The ground layer can also provide a different texture at the bottom of the print.
    Any prop or body part named "Surface" will work if it's polygon density is high enough. That's the tool's magic word. Just select that prop and load the tool. The magnets will lock onto that prop. The automatic nature of the magnets does not work in studio but it's very easy to connect the magnets (deformers).
    Requirements ...
    The Nerd3D Footsteps Tool
    A Nerd 3D Surface Such as the included Disk or Square Field
    Poser 6 or newer or DAZ Studio 2.3 or newer.
    Loading the Tool ...
    The surface figure or "Field" must be loaded before the Footsteps Tool, just like a normal magnet or deformers. In Poser all the magnets will automatically connect to the "Surface" part of the figure. DAZ Studio users will need to do this manually.
    To connect the deformers in Studio
    Select the Surface part of the field figure
    Open the Add Nodes dialog
    Select all the magnets in the tool
    Click Accept
    If you need several tools to create the length of path you want it will probably be easier to add all the nodes at once.
    Magnets Setup
    Path Setup ...
    The path of the effect is easily setup using the Easy Pose dials in the Control Element. (The big cone) if you need more detailed control you can select any of the boot props for individual print adjustments.
    The EasyPose dials should be fairly self explanatory.
    Right - Left All: Uniform curve of path
    Up-Down All: Curve the path up a hill
    Left-Right S: Make an "S" curve
    Up-Down S: Make a vertical S
    Stride Length: More space between steps
    Some of the Track Details can be found in the individual prints as well.
    Print Size: Scales the print uniformly
    Print Length: Makes the print longer
    Print Width: Makes the prints wider
    Track Width: Moves every other print to make the prints farther apart
    Track Angle: Moves all the prints side to side
    Toe In: Moves every other print the opposite direction. Can create a herring bone effect
    Depth All: Makes the prints deeper.
    In most cases you won't want or need to directly change the magnets. In Poser you can keep them hidden by selecting Display > Deformers > Hide All from the menus
    Some tricks ...
    If you want to create a solid path, a tire track or snow board path for example, turn the Print length way up. Start with a setting of about 10. Then turn track width, Toe in, and track angle to 0.
    If you want variation between the prints you can make changes to each print by selecting it's control "Boot" and adjusting dials in there.
    If you need a larger area you can fit 2 Surface Fields together. When working in Poser make sure the correct surface is selected before loading the foot step tool.
    If posing is sluggish turn the surface off till you are ready to render.
    In DAZ Studio don't forget to hide the foot step tools prior to rendering. They won't show in Poser but they will show in Studio.
    The Footstep Fields will work with many existing scenery and sets. Just replace the "ground" of the set with the Footstep Field.
    Super advanced scene integration trick ...
    It's possible in to create a texture from an existing set to apply to the Footsteps Fields. This requires advanced skill in Poser or Studio. Here's a brief rundown.
    Load the set you wish to integrate with
    Load and position the Footstep Field you want to use
    Select the TOP camera and position in so the Field EXACTLY fills the frame. EXACTLY!
    Hide the Field figure and every thing but the set you are integrating with.
    Set one light to pure white and straight above the scene. Turn off or remove other lights.
    Render the scene from the Top camera and at high resolution (3000 x 3000)
    Save that render
    Apply it to the Surface of the Field as the diffuse texture.
    The Studio version has 3 UV sets, make sure the default set is selected. (The others are for tiled textures)
    Restore the textures on the set.
    That will give you a texture closely matched to the existing set's texture. If you want to get really detailed you can copy bump and other maps. Temporarily change the bump map on the set so they are the diffuse texture for the set and render that too.
    Rendering ...
    In Studio be sure to hide the Path and Print Tools before rendering. You can hide the whole tool with one click in the Scene Tab. Click the eye icon next to the Footsteps figure in the scene hierarchy list. This isn't necessary in Poser they will be hidden automatically. DAZ studio users may want to convert the Surface to SubD (Edit > Convert to SubD ... ) this increases the number of polygons and produces a smoother effect. This takes a few minutes and will increase render times.
    Poser owners should make sure "Smooth Polygons" is checked in render options for FireFly. As with SubD in Studio this produces a smoother effect. The included materials take advantage of material room nodes so P4 rendering is not recommended.
    FAQ
    In Studio the Field Figures take like 5 minutes to load! You are using the Poser version of the figures. There is a Studio version that will load in seconds. The Studio version also contains alternate UV sets that are required to make the textures look right.
    Can I use the Footstep tools on other sets? Maybe. The included surfaces are very high polygon and need to be for the footprints to show. If the ground of the other set has enough polygon density then yes.
    Can I manually connect the magnets in poser? Yes, but it's very cumbersome. Each magnets needs to be selected and then slick the "Add Element to Deform" button in properties. Choose the surface. Repeat for all 10 magnets. It's easier to just delete the path tool, make sure the correct object is selected and then reload the path tool.
    Happy rendering
  • masi3veemasi3vee Posts: 353
    Thanks for replying, all.
    I have the documentation, and studied it. I am also using the correct version. Still, when I try to load the tool for making footsteps, tracks, etc, via the Add Node function (in the D-Former Tab), DAZ does not seem to recognize that the Surface layer of the field is indeed selected. So at that point, I can't proceed further.
    I can't help you any further, sorry, I can get it working fine in Poser, and I don't use DS :red:
  • Richard HaseltineRichard Haseltine Posts: 42,724
    It's working for me.
    I load the field, load the footsteps. Then I select the Surface bone (make sure you do have that, not the Ground as I did on my first attempt). Open the DForm pane, click Add node(s), click on each Mag entry on the list. Finally, select teh controller node of the footsteps and dial up the Depth All slider.
    AH Ha!! So it's Multi Steps to get the Footsteps. Hmm... in the cart or not?
  • SzarkSzark Posts: 10,208
    Not to take away anything from this cool tool I just use some home made displacement maps. First one I ever did was Dino prints in mud and sand. Once you get a maker spot for orientation and starting point and size then it is fairly easy and timing consuming at first but cheaper and more flexible. Again this is a nice tool though I don't have it. :)
    Richard, that's the problem. I get as far as seeing the Add Node button, but when I click it, the app says "This action requires that an item in the scene be selected." It is. I seem to be unable to add a node in any scene and can't sort out why. I get the same Selection Error every time.
    Ehm ...
    Load Square Field
    Load Footsteps
    Go to scene tab and select Footsteps <---- maybe it is this step?<br /> Open DForm pane
    Add nodes
    Click (Better ctrl+click) on all magnets
    accept
    Kerya said:
    Ehm ...
    Load Square Field
    Load Footsteps
    Add nodes
    accept
    Thank you... based on your suggestion, I actually got one footstep to work. However, I'm still not clear on how to apply a tire track or other "pose" to the tool. If the footprint is supposed to be lengthened, etc., to create a tire track as suggested in the ReadMe, the existence of a separate "pose" called Tire Track seems a bit cryptic. I don;t quite get that. Some progress, though. So close!
    Post edited by masi3vee on
    Well, I have one tool working for one tire track. I need two, though, but does anyone know how to get two tools working in one field? The documentation suggests that you need a tool for each track, but I can only get one tool working in a field. The second one will load, but will not leave a print.
    I wished I could help you. I didn't forget you, but I couldn't even get the first track to render.
    Could you tell me how you succeeded to do that?
  • nelsonsmithnelsonsmith Posts: 1,133
    Is this product even still available?   Sounds like something I could definitely use, but none of the links you guys have listed leads anywhere now.
  • FixmypcmikeFixmypcmike Posts: 17,300
    No, the vendor no longer sells here.
  • scorpioscorpio Posts: 5,516
  • UnifiedBrainUnifiedBrain Posts: 1,627
    edited October 2016
    Post edited by UnifiedBrain on
