Digital Art Zone
Random Rock shapes in Carrara
Posted: 10 September 2012 03:22 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2008-02-22
Is it possible to create a rock shape, and then duplicate and randomize it…so that there are now like 30 rocks of different shapes?
 Signature
+800 or so old forum posts, just so you know I’m not a newb!  tongue laugh
Profile
Posted: 10 September 2012 04:20 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi 3D outlaw. smile
There are several ways in Carrara to create simple rock shapes,.  such as the Metaball modeller, or the Vertex modeller has an option to Construct / Organic , to take a simple flat shape and make it 3D. (See pics)
If you add a couple of Morphs to that organic object, then you can Duplicate, and change the shape of your rocks, then add those to a surface replicator to apply them to an surface like a terrain.
You can use the options in the Surface Replicator, to rotate and scale them differently.
You can also use the “Create Real”  option, to generate real objects instead of replicated.
Image Attachments
Profile
Posted: 10 September 2012 06:20 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
gee, that mesh looks like my hand stitching when I sew my wetsuits together….
nice to see Contctruct/Organic in action
thanks Andy
 Signature
http://andrewfinnie.blogspot.com.au/
Profile
Posted: 11 September 2012 05:07 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Thanks Andrew smile
It’s one of those neglected features in Carrara, and it’s great for creating simple organic shapes, quickly.
The mesh (mess) is mostly my fault for using an interpolated curve to create the basic flat shape.
if you use a simpler shape, then you can subdivide or tesselate and then sculpt into what you need, and smooth.
lower poly example smile
Image Attachments
Profile
