Digital Art Zone
18 of 21
18
Carrara Academy
Posted: 26 October 2012 09:02 AM   [ Ignore ]   [ # 256 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Just in case any of you folks are interested in playing with new stuff,...
Pycloid “beta” for carrara is available
it’s an enhanced particle system, including fluids..
you can read about it here….
http://www.daz3d.com/forums/viewthread/10339/
Profile
Posted: 26 October 2012 09:13 AM   [ Ignore ]   [ # 257 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
lol, downloaded the zip to my android hours ago, still have not added it to my desktop, got lots of things I need to get off my tablet to use!
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 26 October 2012 11:45 AM   [ Ignore ]   [ # 258 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI Wendy smile
LOL .. I just knew you’d have it… smile
It’s quite fun to play with, and nice to watch, ..but some of the settings seem a bit strange, and I don’t see a way to start it emitting before the animation begins. .. early days.
Profile
Posted: 26 October 2012 12:15 PM   [ Ignore ]   [ # 259 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
busy rendering something lengthy at the moment, I say moment but more like 24hours!! 2hours in.
massive scene complete Moonshine diner with animated skeletons in all the seats and 41lights and the 41st is replicated a hundred times along the neon sign outline
some skeletons are replicated but at least 28 unique figures.
actually rendering surprisingly quick considering (2min per frame)
 Signature
Profile
Posted: 26 October 2012 04:20 PM   [ Ignore ]   [ # 260 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
What? You’re not gonna entertain us with one of your “example/intro” animaions, are you, Andy? raspberry
 Signature
An expert is just an experienced novice.
Profile
Posted: 26 October 2012 04:26 PM   [ Ignore ]   [ # 261 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
I still get a chuckle out of this one:
http://www.youtube.com/watch?v=2AMRd08KOEU
 Signature
Profile
Posted: 26 October 2012 09:08 PM   [ Ignore ]   [ # 262 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
Well, the Bridge thing worked and then I just flattened the polys it made. But after I bridged, it made weird lines. I don’t know what they are, but I can’t select them to delete them.
Image Attachments
 Signature
Profile
Posted: 27 October 2012 06:17 AM   [ Ignore ]   [ # 263 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
I don’t use wings3D but it looks like some edges or vertices have been bridged to the bottom part somewhere.
You could make this part in Carrara’s Spline or vertex modeller.
Also, if you have a vector drawing program, and can export AI or EPS, then you can draw the shape,. and import that into the spline modeller, then give it depth
Image Attachments
Profile
Posted: 27 October 2012 06:20 AM   [ Ignore ]   [ # 264 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
I’m still trying to figure out what all the controls in Pycloid do,. then I’ll make a couple of clips.
smile
Profile
Posted: 27 October 2012 06:48 PM   [ Ignore ]   [ # 265 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
Oh, c’mon, Andy. You can figure anything out with just a look.  raspberry
What vector program did you use?
 Signature
Profile
Posted: 28 October 2012 06:46 AM   [ Ignore ]   [ # 266 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI Jacob smile
I use a program called Xara designer pro,. but you could also use Photoshop or (I think) paint-shop pro, and Gimp, since they all have “pen” tools to allow you to draw vector line shapes.and should be able to export as EPS
but… you don’t “need” to do it that way, it’s just a quick way to import the shape.
You can draw directly in the spline modeller in Carrara, and you can refine the shape using the little bezier handles on each vertex.
Once the basic shape is created,. you can adjust the extrusion depth by adjusting the default line on the floor, and you can Add bevels,. or you can convert it into a Vertex model,. instead of a spline,. then edit it further in the vertex modeller.
it’s just a quicker way to get that basic shape, without the struggle.
Another way would be to use a “path Sweep” in the vertex modeller,. you’d make a rectangle, and then a curvy line shape.
You’d select the rectangle,. then click on the Path sweep tool,. and then select the curvy line,. and it’ll make a new shape by extracting the rectangle shape along the curvy line path.
smile
Profile
Posted: 28 October 2012 09:52 PM   [ Ignore ]   [ # 267 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
I simply can’t find the Pen tool. But i only have PSE7.
 Signature
Profile
Posted: 28 October 2012 10:10 PM   [ Ignore ]   [ # 268 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
Changing the shader on the pycloid preset examples seems to break them
LightofHeaven - 05 November 2012 11:05 PM
What’s the best way to make a string tied through a hole?
probably drawing a polyline through it in the assembly room with the spanner icon clicky clicked, then you could extrude a tiny shape along it.
hope you see this, I am avoiding addict status, will mention on Skype.
 Signature
Profile
Posted: 29 October 2012 05:41 AM   [ Ignore ]   [ # 269 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi Wendy smile
I also got some errors just loading a couple of the sample files,.. strange.
I was trying to build up particles, filling a glass, and I can see that it’s possible, but it seems to take a long time before they start to build,.. I’m probably doing something wrong.
Jacob smile
I’m not sure if PS elements has the pen tool, but it should be in the main toolbar. ..pic
Image Attachments
Profile
Posted: 05 November 2012 11:05 PM   [ Ignore ]   [ # 270 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
 Signature
Profile
18 of 21
18
