Digital Art Zone
2 of 21
2
Carrara Academy
Posted: 13 September 2012 07:54 PM   [ Ignore ]   [ # 16 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
I can’t decide if I’m smart or stupid, but I figured it out.
 Signature
An expert is just an experienced novice.
Profile
Posted: 13 September 2012 08:11 PM   [ Ignore ]   [ # 17 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
LightofHeaven - 13 September 2012 07:54 PM
That’s good. My answer to the first part was YES! tongue rolleye
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 14 September 2012 03:41 AM   [ Ignore ]   [ # 18 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
Um…WENDY? How do you change tweeners?
And Jeff, what was your answer to the second part? *nudge, nudge* raspberry
 Signature
Profile
Posted: 14 September 2012 11:23 AM   [ Ignore ]   [ # 19 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI All smile
Tweener changing…
You select the Gap’s between two, or more key-frames, (where the tweeners are), then look on the right hand side ,to the tweeners area, click on the text which says linear or bezier, and you’ll get a drop down menu, where you can select a different type of tweener.
smile
Image Attachments
Profile
Posted: 14 September 2012 11:35 AM   [ Ignore ]   [ # 20 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
On the Hair questions,...
The Cut tool, when you select it, will show only the Guide hairs (you can add more or remove guide hairs) and the Cut tool will let you click and cut the length of the guide hairs,.
It’s easiest to have either specific areas of guide hairs or define Hair Groups, so that you can create a fringe, (or “bangs”)
Different hair groups also allow you to apply different hair shaders to each group, which can define the colour, but can also be used to shape the hair, by adding Curl, Kink, Frizz, Clump and adjust the length of the hairs, and add variations to all of those.
The Guide hairs can either be Brushed into a basic style, or can be individually dragged into a shape, you can also adjust the position of the “Control Point” along the length of the hair, from root to tip, which allows you to brush or drag the guide to shape the hair in different directions at the Mid point, or ends, without effecting the rest of the shape.
It’s a complex tool, and as the Hair shaders can also be used to shape and style the hair, it becomes even more complex.
Holly is the Guru smile
Profile
Posted: 14 September 2012 03:19 PM   [ Ignore ]   [ # 21 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
Andy! Gaood to see you here. Hope things are settling down a bit for you.
Oh man, I was looking all over the TIMELINE for ‘em sneaky tweeners. Never expected them to be right next to my head.
 Signature
Profile
Posted: 15 September 2012 12:50 AM   [ Ignore ]   [ # 22 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
Well, I tried. lol
http://www.youtube.com/watch?v=sSheB02QB7Y&feature=youtu.be
 Signature
Profile
Posted: 15 September 2012 02:19 AM   [ Ignore ]   [ # 23 ]
Active Member
Avatar
RankRank
Joined  2007-04-08
It’s ANDY!!!
Dude, you don’t visit my thread and it needs some regular Scotland.  It’s got regular England, regular America and regular Wales.  Needs some regular Scotland.  And on a personal level, I miss your insight!
Now, back to topic:  I am a HUGE fan of Carrara, but also becoming a huge fan of Genesis.  Main reason I want my work to be done in DS is because it’s got a larger user base than Carrara.
I am looking at that tutorial you put up, for fire, and some things don’t seem quite right but I can’t put my finger on them because my knowledge of Carrara and particles isn’t good enough.
I am going to start saving some money for when the next incarnation of Carrara is released and I can use Genesis with it.
 Signature
Old Post Count:  Who cares?
Profile
Posted: 15 September 2012 03:03 AM   [ Ignore ]   [ # 24 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
You have me wondering what it could be you can’t put your finger on. lol
The logo tut left out a few parts that I had to figure out on my own.. I don’t know about the fire tut though, because my friend couldn’t finish scripting it for me to understand.
 Signature
Profile
Posted: 15 September 2012 06:02 PM   [ Ignore ]   [ # 25 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
Man, I don’t get it…yet.
Let’s say I want to make a flaming sphere with tongues of fire dancing in every direction, like the sun. So…
Pic 1: I opened a small scene and scaled the timeline to 00:06:00. Then, I inserted a sphere and particle emitter into the scene and put the settings shown in the first screenshot.
Pic 2: In the shader room, I made the texture from the particle fire video tut.
pic 3: I scrubbed forward a bit on the timeline and rendered the frame. This isn’t the flickery result I wanted. It just makes a huge flamy ball around my sphere.
Image Attachments
 Signature
Profile
Posted: 16 September 2012 08:44 PM   [ Ignore ]   [ # 26 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
I ain’t got no, I ain’t got no, I ain’t got no
Inspiration
 Signature
Profile
Posted: 18 September 2012 12:41 AM   [ Ignore ]   [ # 27 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
So,I’m reading about forces in the Carrara manual. I understand a flow force can be used to simulate wind, damping force is like rolling a ball through sand, and torque force is like a spinning fan. But I don’t really get directional and point forces. They sound like push and pull, respectively.  So what’s the difference? Can’t you just put a sphere here, scrub forward and set a key frame?
 Signature
Profile
Posted: 18 September 2012 01:07 AM   [ Ignore ]   [ # 28 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
they work with physics and hair!
once you start playing with physics! you are addicted!
get a sphere, stick it above a plane
in motion choose physics instead of keyframe
click the sparkly fairy wand on the left top of the screen
see ya tomorrow!!!
(that is how Andy addicted me! I thought it was complicated
it is not!
like playing with dominoes!! you can do dominoes too! everyone does!!!)
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 18 September 2012 10:07 PM   [ Ignore ]   [ # 29 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
How do you control which way the directional force shoots the sphere?
 Signature
Profile
Posted: 19 September 2012 05:32 PM   [ Ignore ]   [ # 30 ]
Active Member
Avatar
RankRank
Joined  2011-01-13
I give up.
I was trying to make my sphere go splat on the wall, like someone threw mud at it. But all it’s doing is going down.
Not finding much help either.
 Signature
Profile
2 of 21
2
