Digital Art Zone
copy surface settings??
Posted: 09 September 2012 05:32 PM   [ Ignore ]
Member
Rank
Joined  2003-11-09
is there a simple way to copy all the surface settings of an item and paste them to another item??
TIA.
 Signature
Profile
Posted: 09 September 2012 06:12 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2003-10-09
Just highlight the top line, all will be selected, select the other object same way and paste
However, the receiving object must have the same shader nodes.
You cannot paste from, say, HSS shader to standard
Profile
Posted: 09 September 2012 06:28 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2003-11-09
well.. it’s not a complete object… for example… say you had a shirt with contrasting cuffs… i want to copy the sleeve settings to the cuff….
HSS shader->standard??? you ‘bout lost me on that one….
Thanks!
 Signature
Profile
Posted: 09 September 2012 07:13 PM   [ Ignore ]   [ # 3 ]
Active Member
RankRank
Joined  2003-10-09
You said at first, “All the surfaces”...
It is just ordinary copy and paste.
Again assuming they have similar nodes.
The example I give of HSS is Human Surface Shader.  It has extra nodes for Velvet, Subsurface Scattering, Specular2, and so on.
The number and type of nodes has to match or the copy will not complete.  Simple paste does not create nodes
Image Attachments
Profile
Posted: 09 September 2012 07:16 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2003-11-09
i think i got it now…
thanks for the pic and all! smile
 Signature
Profile
Posted: 15 September 2012 12:54 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2012-03-25
Medzin - 09 September 2012 07:13 PM
I always prefer to use keyboard shortcuts because I absolutely hate having to go into the menu list repeatedly especially when working with multiple objects.
That said;
Q: Please can someone tell me what is the keyboard short cut for copy/paste surface?
((PS: In Bryce I think it’s Ctrl+Alt C and/then V whereas this function does not work in DS4))
Profile
Posted: 15 September 2012 02:44 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
Sara16 - 15 September 2012 12:54 PM
Afaik there isn’t one, you can copy/paste parameter settings with Ctrl+C & Ctrl+V just not surfaces.
 Signature
**shuffles of with a new headache** tongue wink
Profile
Posted: 15 September 2012 03:55 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
You can, of course, assign a new shortcut in Window>Workspace>Customise (Edit>Customise in older versions of DS), by finding the command in the left-hand column, right-clicking on it and choosing the change short cut option. Of course there aren’t many free shortcuts to choose from now.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 15 September 2012 06:43 PM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2012-03-25
Thanks guys!
I’ll look in customize and see what I can whip up.
Profile
