Digital Art Zone
Finally Using Old Sets For New Render
Posted: 09 September 2012 04:21 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2005-08-26
So after owning some of the house sets Here for a long, long while, I’ve finally taken them into Carrara. So far my draft looks O.K. There will be a change, perhaps a backdrop might work, or I’ll put plains in the background to keep the ugly ground from showing outside the windows…. I’ve textured everything I could in C8 shaders (oak wood for the patio furnature, Bright Eyes for Carrara for V4’s eyes, Carrara ‘steel’ for the patio cover, C8 blue tiled marble for the pool’s linining, with white marble for the steps. I’ve used the default water texture for the water itself. I’ve put spot lights in all the ceiling lights that are in the bedroom’s textures, and bulbs in the lamps after editing out the mesh’s light bulb, and scaling the light bulb to their exact sizes. Two pots in the background (won’t even be visible for this render) are using a C8 stone texture.
I have one issue when doing a ‘preview’ type render (No global lighting or indirect): The water looks like mud, can’t see through it, it just looks like a solid block. But when I see it through the preview cam I have set up: it looks ok. Renders even without all the lighting so far takes around 2hrs.
Before I do the final render, I’d like to know if this issue is likely to go away once I use indirect lighting with light through transparency, and caustics. I had a snapshot of the rendered water at one point, but C8 crashed while I was making normal maps for V4’s dress (perhaps I shouldn’t have been rendering my texture editor (Shader Map 2) while having C8 and DS open all at the same time, lol).
I guess that’s my only concern at this point. If the water will actually appear clear once I enable indirect lighting and transparency. I’musing the other set from the dream home Here for the yard, and am using a replicator to generate trees throughout the yard. It’s kind of my biggest screen attempt yet… Especially using Carrara standard
Image Attachments
 Signature
My Renders: My DeviantArt Gallery
Revenger is always looking to meet 3d artists of all levels. FB me if you want to share, or just hangout in the background: http://www.facebook.com/revenger681
Profile
Posted: 09 September 2012 04:43 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2006-06-12
I don’t know if you have done this or not, but you can change the water to Carrara water in the Shader Room.
That will get you a better render.
 Signature
There is a serious tendency toward capitalism among the well-to-do peasants.
Mao Tse-Tung
Profile
Posted: 09 September 2012 04:47 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2005-08-26
tsarist - 09 September 2012 04:43 PM
Hm. I think I’ll do just that! I’ve contemplated doing it before, Since I figured it’d be MUCH more real looking than the default texture intended to be used for daz studio smile
I just figured I’d see how the default texture would do first. But perhaps I’ll change it now.
 Signature
Profile
Posted: 09 September 2012 05:03 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2005-08-26
Advice taken. Render in progress… Will report back in… Um.. 8 hours? lol smile
 Signature
Profile
Posted: 09 September 2012 10:01 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2005-08-26
ok, here’s the new scene with a just finished render… I applied the C8 shader, it’s still a solid block. I hate this, happens every time. I enabled transparency and I still get the weird looking water…. Grr….
Image Attachments
 Signature
Profile
Posted: 09 September 2012 10:17 PM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Is it my eyes or is EVERYTHING just a little bit out of focus? I am trying to be helpful, I just do not use Cararra. I have 6 but not on this PC.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 10 September 2012 12:14 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2005-08-26
It’s probably because I have aa and all the other settings set to min. Because it was a sort of “preview” render. I always do that, then turn them up in the final. Btw I fixed the water issue!
 Signature
Profile
Posted: 10 September 2012 11:56 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Ah, I think it will be a darn good render at final. I can’t wait to see it.
 Signature
Profile
