Digital Art Zone
Reality 2 problem: why does it do this when I try to load these textures?
Posted: 28 May 2012 07:38 AM   [ Ignore ]
Member
Rank
Joined  2011-09-10
when I try to load M4 genitals on Daz and then try and render a scene with reality 2 it comes up with “M4 Genitalia is a Sub D figure. Sub D is undocumented by daz and cannot be accessed by reality”
What does this mean please??!! is there something I can do?
Profile
Posted: 28 May 2012 08:06 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I think if you select the item and set the Mesh resolution to base in the Parameters pane it will work. SubD is the process used to smooth the mesh, but it’s done by the 3Delight renderer and therefore not available to Reality.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 28 May 2012 02:18 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2011-09-10
Richard Haseltine - 28 May 2012 08:06 AM
sorry can you elaborate on this pls? I selected the item but there is no mesh resolution option in the parameters tab. This is daz 3.1 by the way.
Profile
Posted: 28 May 2012 03:48 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Sorry, I think I saw M4 and read it as DS4. Unless you’ve customised the figure just save a pose preset and a character preset for the genitals then reload them from the library and in PowerLoader go to the Advanced tab>Mesh resolution subtab and uncheck Convert to Subdivision Surface. Conform to M4, apply your pose and character presets to get it back to where it was and it should work.
 Signature
Profile
Posted: 31 May 2012 01:00 PM   [ Ignore ]   [ # 4 ]
Active Member
RankRank
Joined  2012-02-04
Toobis - 28 May 2012 07:38 AM
This sounds like you are using DS3.  Subdivision export in the DS SDK is one of the things that DS4 provides proper support for, while DS3 did not.  Reality will read subdivision just fine in DS4.
 Signature
My deviantART Homepage
Profile
