I’m still hoping to get at least a more definitive answer here.
But you had your answer via the e-mail.(Official Answer From Daz)
To quote:-
It’s only a problem if the mesh is derived from a protected figure. Simply having the mesh fit to the geometry of such a figure is not a problem in and of itself. If you took the Genesis geometry and then modded it to make an outfit, that would be a violation of the terms of use.
So, simply having a mesh fit to the geometry, (shrink wrapping is fitting) is not a problem.
It is like I mentioned earlier, it is the mesh that is copyrighted, not the form.
