Digital Art Zone
5 of 6
5
mcjTransport, model/animate spline based tubes - Version 1 is out !!
Posted: 19 September 2012 06:15 PM   [ Ignore ]   [ # 61 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Kendall Sears - 19 September 2012 05:43 PM
Is the plugin coded so that an extension could be written to use SVG files for path input?
Kendall
Shhhh!!!!!!
We want him to finish it up sometime in the near future (although that would be a great feature to have…)
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 19 September 2012 06:19 PM   [ Ignore ]   [ # 62 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
Kendall
it’s a script, so someone could write a curve importer, though that someone would probably be me
another solution is to write a script that converts svg to the text format i use (shown below )
and have the ability to select one curve from the many in the svg file
i didn’t know about svg, but if i guess it would be a good choice ... someday someday smile
type mcjLathe
vrsn 2009.11.25
twld false
bwld false
clsd false
nsds 8
nsgs 1
v 0.5 0.5
-0.45 0.5
v 0.27 0.508
v 0.5 0.50
v3d 0 0 45.59
v3d
-42.1 0 45.59
v3d 0 0.00 -46.2
Profile
Posted: 19 September 2012 06:26 PM   [ Ignore ]   [ # 63 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Casual - 19 September 2012 06:19 PM
Kendall
type mcjLathe
vrsn 2009.11.25
twld false
bwld false
clsd false
nsds 8
nsgs 1
v 0.5 0.5
-0.45 0.5
v 0.27 0.508
v 0.5 0.50
v3d 0 0 45.59
v3d
-42.1 0 45.59
v3d 0 0.00 -46.2
I was just wondering if someone like me could write an import routine.  Is there any docs on your import data?  Is there a way to set the diameter of the line in the txt file?  Can it handle complex paths?  Multiple paths?  If no on the multiple paths, is there a set reference point so that multiple runs could create colocated tubes?
EDIT:  There are *many* projects that I could use this for if only I could get a SVG file into it.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 19 September 2012 06:58 PM   [ Ignore ]   [ # 64 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
Kendall Sears - 19 September 2012 06:26 PM
Kendall
the format was established when i wrote mcjLathe
a few named parameters, followed by a list of vertices, the x coordinates range from -0.5 to 0.5 the y coordinates range from 0 to 1
if you run mcjLathe ( https://sites.google.com/site/mcasualsdazscripts/mcjlathe ) or mcjSuperLathe ( https://sites.google.com/site/mcasualsdazscripts/mcjlathe ) you can save the curves you create to disk and inspect them
indeed there’s only 1 curve per file
i was thinking .... maybe i could write a dxf importer since eons ago i wrote one. and i would think there’ svg-to-dxf converters floating around the internet
the index for my web site is https://sites.google.com/site/mcasualsdazscripts2
here is a complete 4-points curve from ncjSuperLathe
type mcjLathe
vrsn 2009.11.25
twld false
bwld false
clsd false
nsds 8
nsgs 2
note vertex coordinates
first column is x second is y
note X must remain in the [
-0.5,0.5] range
note Y must remain in the [0.0
,1.0] range
v 0.5 0
v 0.15 0.15
v 0 0.5
v 0.15 0.85
v 0.5 1
the new upcoming script, mcjTransport involves 3D curves,
so i append the 3D coordinates using the new token “v3d”
type mcjLathe
vrsn 2009.11.25
twld false
bwld false
clsd false
nsds 8
nsgs 2
-0.5,0.5] range
,1.0] range
v 0.5 0
v 0.15 0.15
v 0 0.5
v 0.15 0.85
v 0.5 1
v3d 0.5 0 0
v3d 0.15 0 0.15
v3d 0 0 0.5
v3d 0.15 0 0.85
v3d 0.5 0 1
Profile
Posted: 20 September 2012 11:47 AM   [ Ignore ]   [ # 65 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
i’m giving it another go today, remember the ‘monotone’ feature, which removed “kinks” from the tube’s path,
well it’s not an integral part of the mcjTransport yet.
There’s that and not much more left to do.
So hopes are high ... as a kite.
nah hopes are up in a lemon tree
and today’s song is http://www.youtube.com/watch?v=IsP8r3X_VfY
( the original being http://www.youtube.com/watch?v=phEnpdDusss )
Image Attachments
Profile
Posted: 20 September 2012 09:48 PM   [ Ignore ]   [ # 66 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
news
Catmull-Rom splines ( http://en.wikipedia.org/wiki/Cubic_Hermite_spline ) will be used instead of Studio’s animation curves
this, to make neat looking loops ( closed paths )
shown below: a 30 frames long, 4-keyframes closed path
other news is, the path monotonizer function is now part of mcjTransport
Image Attachments
Profile
Posted: 21 September 2012 03:36 PM   [ Ignore ]   [ # 67 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
news from the coding front
the part of the script that ensures clean looping paths was tested some more and corrected
and i’m thinking about adding SecondLife Sculpties export
here you see a 4-keyframes path ( the tube on the ground ) using the Catmull-Rom spline
( the head of Disney/Pixar http://en.wikipedia.org/wiki/Edwin_Catmull
is a computer scientist/mathematician and he developped that spline,
which is a variant of Hermite Splines )
Image Attachments
Profile
Posted: 22 September 2012 02:16 PM   [ Ignore ]   [ # 68 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
that’s the test scene for
- the functions that let mcjTransport export animated-marker-paths as 2D and 3D curves
those 2d curves can then be re-used by mcjTransport, mcjLathe and mcjSuperlathe
- the functions that let mcjTranslate use 2D curves created by mcjTransport, mcjLathe and mcjSuperlathe
not sure when it will all be ready, so i wont give deadlines smile
Image Attachments
Profile
Posted: 23 September 2012 01:08 PM   [ Ignore ]   [ # 69 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
that’s a 368-segments path, created with the help of the mcjCollider plugin ( for DS3 only )
the collider was colliding against the torso nodes of the mcjA3Maillot figure
the collider was parented to a camera which was parented to a null, which was going up down up while rotating 4320 degrees
the null’s animation was linearized using my setInterpolation script
i selected the collider node and ran this script shown below
for each frame, the script moves the collider back to the camera and points it straight ahead at the figure
then it fires the collider which moves to the surface of the figure
one could use this method and mcjRibbons, mcjTracePath  ( or soon mcjTransport ) as a base for creating clothes
or to lay roads on an uneven terrain
note that since her movements are not hindered this does not count as bondage, so there
the second image, the animated gif, was done by animating the “vertical tile offset” parameter of the surface material. using the matAnim script
// DAZ Studio version 3.1  filetype DAZ Script
var tick Scene.getTimeStep();
var
node Scene.getPrimarySelection()
var
range Scene.getPlayRange()
var
startFr range.start tick;
var
endFr range.end tick;
var
zeropos DzVec300);
var
xr node.getXRotControl()
var
yr node.getYRotControl()
var
zr node.getZRotControl()
for( var
startFr<= endFri++ )
 Scene
.setFrame);
processEvents();
node.setLocalPoszeropos );
xr.setValue(-90)
yr.setValue(0)
zr.setValue(0)
node.activated();
Image Attachments
Profile
Posted: 23 September 2012 02:35 PM   [ Ignore ]   [ # 70 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Casual - 23 September 2012 01:08 PM
If you animated the Ambient, you could make it look like she’s wearing blinking lights…
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 23 September 2012 03:28 PM   [ Ignore ]   [ # 71 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
mjc1016 - 23 September 2012 02:35 PM
with randomized tiling offsets and noise we get glitter
( this post’s music background is http://www.youtube.com/watch?v=dCIMqI39DCI )
Image Attachments
Profile
Posted: 23 September 2012 03:55 PM   [ Ignore ]   [ # 72 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Looks like a fun way to do a Christmas tree…
Extrude a tube around the tree…use matAnim to animate a color pattern…make an animated gif…presto, blinking lights on the tree!
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 23 September 2012 04:35 PM   [ Ignore ]   [ # 73 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
~ breaking mcjTransport news ~ ~ breaking mcjTransport news ~ ~ breaking mcjTransport news ~
i will be posting the first version of mcjTransport this evening ( it’s now 6:32 pm )
and i’ll complete the user manual
so, you’ll have to keep an eye on this thread to get the finished manual and possibly re-download the script
Image Attachments
Profile
Posted: 23 September 2012 07:38 PM   [ Ignore ]   [ # 74 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
- Release—Release—Release—Release—Release—Release -
https://sites.google.com/site/mcasualsdazscripts2/mcjtransport
Here’s version 1 of mcjTransport
it was developed on Daz Studio 3.1 advanced, so that’s where it was the most tested
i did some tests on Daz Studio 4.5 and will do more tonight.
i included a version for Daz Studio 1 and 2 but did not test it at all yet
so, stay tuned to this thread for new versions of the script and the manual
fig. 1 : a 7-keygrame path, with a 10-turn twist added
Image Attachments
Profile
Posted: 24 September 2012 07:28 PM   [ Ignore ]   [ # 75 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
~ update ~~ update ~~ update ~~ update ~
the version for Daz Studio 1 and 2 now works
the version for DS3, 4, 4.5 had a tiny change to prevent accidental creation of monster tubes encompassing the known universe
the manual was improved
__________________________________
version history
sept 24 9 pm Version for DS1 and DS2
sept 24 early morn. Version 3 limited the maximum segments to 4096 to prevent accidents
sept 23 9:15pm Version 2
sept 23 9pm Version 1
Profile
5 of 6
5
