Digital Art Zone
3 of 6
3
mcjTransport, model/animate spline based tubes - Version 1 is out !!
Posted: 13 September 2012 03:39 PM   [ Ignore ]   [ # 31 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Wow, it hasn’t been easy for you, but it looks like you got there in the end.  Good thinking!
Profile
Posted: 13 September 2012 05:45 PM   [ Ignore ]   [ # 32 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
the keen eye will have noticed that in the first post, i mentioned the word “animated”
well, each time you’ll run mcjTransport, you ‘ll have the option of specifying a new morph name
so you can have as many tube-shapes as you want for the same tube
in the image below i created 3 morphs/shapes
then i animated their morph strength
so using this, you could have Aiko plugging her guitar’s cable in the Amplifier
as in this scene
http://www.youtube.com/watch?v=_Dvwd8Hyh-Y
at frame 0,  // morph1 at 100% // morph2 at 0% // morph3 at 0%
at frame 10, // morph1 at 0% // morph2 at 100% // morph3 at 0%
at frame 20,  // morph1 at 0% // morph2 at 0% // morph3 at 100%
at frame 30, // morph1 at 100% // morph2 at 0% // morph3 at 0%
Image Attachments
Profile
Posted: 13 September 2012 06:11 PM   [ Ignore ]   [ # 33 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
i thought i’d have the script ready today, but there’s one last and important feature i want to add
remember the image of the road in page 2 of this thread, the road was horizontal
in another case it was twisting a specified number of times
i’ll add the possibility to tweak the “roll” (sideway tilt )  of the road
this is essential if, for example you want a flat ribbon to wrap around a character’s arm or leg
so ... you’ll have to be patient smore
Image Attachments
Profile
Posted: 13 September 2012 07:59 PM   [ Ignore ]   [ # 34 ]
New Member
Avatar
Joined  2006-04-30
Better and better!
Profile
Posted: 14 September 2012 02:41 AM   [ Ignore ]   [ # 35 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
These boots look terrific!  It is hard to believe that it can be done in DS.
Profile
Posted: 14 September 2012 07:03 AM   [ Ignore ]   [ # 36 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
JimmyC_2009 - 14 September 2012 02:41 AM
well actually they were not done in DS,
i was trying to illustrate, that mcjTransport could be used to create flat ribbons, that follow a character’s leg or arm
so you could make the strings and straps using mcjTransport
the rest of the shoe would still be done in a modeler like Hexagon or Blender
though, the shoes for A3 are available free over here
http://www.daz3d.com/forums/viewthread/4670/
they are props, not a “real” figure but still usable
Profile
Posted: 14 September 2012 07:06 AM   [ Ignore ]   [ # 37 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
as of this morning this is the UI
The simplest use would be like this
- select the number of sides and segments for your tube
- press the “build” button
- set Daz Studio’s timeline appropriately
- create a null
- animate the null, which creates a path
- press the “update tube” button
- done
Image Attachments
Profile
Posted: 14 September 2012 07:12 AM   [ Ignore ]   [ # 38 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
I like the interface too.  Yes, my post was a bit confusing in regard to the shoes, I only meant the straps, that was staggering enough for me smile
When you get around to producing a script that can do shoes as well, can I be your business manager?
Profile
Posted: 14 September 2012 09:14 AM   [ Ignore ]   [ # 39 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
so here’s the last piece ( well maybe i’ll add something) of the puzzle
the “roll” of the animated marker ( the square with green lines ) is transfered to the tube
the animation of the marker is just 3 keyframes on a 32-frames playrange
Image Attachments
Profile
Posted: 14 September 2012 12:27 PM   [ Ignore ]   [ # 40 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
knotty tube with (non-tiling) voronoi bump map
Image Attachments
Profile
Posted: 14 September 2012 12:38 PM   [ Ignore ]   [ # 41 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Looks like a knotted hose pipe.  There must be loads of uses for this script.  I am really going to get into this one when it is released.
Brilliant work!
Profile
Posted: 14 September 2012 06:24 PM   [ Ignore ]   [ # 42 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
looks like i’ll need one more day
i added the possibility to save a path as a profile curve
so you will be able to create profile curves without using mcjSuperLathe
also, the profiles dont have to be closed loops ( so i guess that’s no longer called ‘tubes’ )
Image Attachments
Profile
Posted: 14 September 2012 06:34 PM   [ Ignore ]   [ # 43 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Casual - 14 September 2012 06:24 PM
Umm….while you’re at it, could you possibly get it to wash the dishes? grin
This is looking fantastic.  Take all the time you need…
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 15 September 2012 09:15 AM   [ Ignore ]   [ # 44 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
i’m adding the possibility of welding the vertices at the beginning and at the end of the tube
( since it was available in mcjRibbons, mcjLathe and mcjSuperLathe )
Image Attachments
Profile
Posted: 15 September 2012 09:24 AM   [ Ignore ]   [ # 45 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Welding is good.  It looks useful.
Profile
3 of 6
3
