Digital Art Zone
‘Renderer not found’ when running DAZ from external application
Posted: 07 September 2012 03:02 AM   [ Ignore ]
New Member
Joined  2009-10-15
I have an external program, which calls DAZ via the SDK.
Basically the flow is:
Start up DAZ studio
Load up various objects and pose presets
Do a series of renderings with various objects turned on and off
Exit DAZ studio
This worked fine with DAZ < 4.5 - Unfortunately this is no longer the case.
Each render is done by the call:
dzApp->getRenderMgr()->doRender( renderOptions );
which now just gives me a msg box saying: “Unable to render, no rendering engine available”
The call to
dzApp->getRenderMgr()->getNumRenderers();
Showed that I have a grand total of 0 available renderers - at least the msg box makes sense smile
So the question is:
How do I get access to a valid 3Delight renderer when I start DAZ studio via an external program?
Any input/help will be greatly appreciated.
Cheers
Spielereinz
Profile
Posted: 07 September 2012 05:10 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I assume you can render directly, with cmd/ctrl-r?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 07 September 2012 05:25 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2009-10-15
If I start the program normally - yes
Running via app->run(DzApp::FullInterface) - no (same error msg)
Profile
Posted: 07 September 2012 07:50 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Make a bug report then, please.
 Signature
Profile
Posted: 10 September 2012 03:24 AM   [ Ignore ]   [ # 4 ]
New Member
Joined  2009-10-15
NOTE:
This only happens in the 64 bit version. 32 bit works fine.
I’ll submit a bug report when time permits.
Profile
