Digital Art Zone
4.5 Different from 4
Posted: 06 September 2012 06:16 PM   [ Ignore ]
Member
Rank
Joined  2006-03-05
I know this sounds dumb but…
I upgraded to 4.5 and when it started the figure shows with a box around it, A render box, I hit render and its whats inside the box. How can I change the setting to get the whole window?
Profile
Posted: 06 September 2012 06:21 PM   [ Ignore ]   [ # 1 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Render settings, Go to the Advanced section and in Presets change it to Active Viewport.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 06 September 2012 06:41 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2006-03-05
Just found that thanks. Really glad you understood my babble there.
Profile
Posted: 06 September 2012 08:26 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2011-07-31
And you may have to reset it each time you reopen 4.5.
 Signature
AtticAnne in Austin TX
FREE GANGSTER RPG GAME
Profile
Posted: 06 September 2012 08:29 PM   [ Ignore ]   [ # 4 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Yes, Anne is right. The Render settings go back to ???? every time you open 4.5. So be sure you set them before you render each time. They will not be saved from your last use of DS.
 Signature
Profile
Posted: 07 September 2012 02:58 AM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
This bug has been reported and fixed for the next version.
Profile
Posted: 07 September 2012 03:14 AM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  0
FWIW I am not seeing that bug in 4.5 pro 64 bit.
My render settings are remembered
Profile
Posted: 07 September 2012 04:07 AM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Strange - I am on Win 7 64 bit, and I have to reset my render display every single time I run DS 4.5.  I wonder why it worked on some systems and not others?  Well, it is fixed now for the next version, and we should all have it working them.  I hope yours doesn’t break then smile
Profile
Posted: 07 September 2012 07:48 AM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  0
I just double checked mine by changing from new window to image file and closing studio.
Settings remembered when studio opened back up.
Could it be because I have preset set to custom ?
Profile
Posted: 07 September 2012 08:07 AM   [ Ignore ]   [ # 9 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Mine is set to Custom as well, but it always comes up with 569 : 353, no matter what Presets I save.  I can see my saved one briefly for about half a second, then it reverts to it’s own annoying format.  Fixed now anyway (I hope)
Profile
Posted: 07 September 2012 11:24 AM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  0
This is very strange but as you say it’s now fixed. Just as a matter of interest my custom preset is 1280 : 1024 and has been carried over from DS4 through the last 2 RC builds of 4.5 and onto the final release
Profile
Posted: 07 September 2012 05:42 PM   [ Ignore ]   [ # 11 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Is it possible that the settings are saved if you don’t have a default scene load on startup?
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 07 September 2012 05:45 PM   [ Ignore ]   [ # 12 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Mine only changes at random times. I’ve not figured out just what triggers the change. It will be fine four or five times and then just change.
 Signature
Profile
Posted: 08 September 2012 02:51 AM   [ Ignore ]   [ # 13 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
I tried that Mike, I was full of hope because I never used to load the Genesis figure, but now it only takes a couple of seconds, so I load it every time.  Changing that did not work, still does the same thing.
@Jaderail
Mine does it EVERY single time I load DS 4.5, without fail.  It is not the end of the world, but it does get very old very quickly.  smile
Thanks lads!
Profile
