Digital Art Zone
Cyborg test render
Posted: 04 September 2012 02:16 PM   [ Ignore ]
Member
Rank
Joined  2011-05-15
Picked up the Cyborg character on sale today. Did a quick and dirty render. He’s pretty neat. smile
http://www.youtube.com/watch?v=ixgpZltihJs
Image Attachments
 Signature
Swing by and Subscribe: http://www.youtube.com/dumpprep
Profile
Posted: 04 September 2012 02:22 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2012-04-01
Yepp, awesome character, here are my quick renders. Still having issues with detached pistons, even after trying Dzfires recommendation to reload and avoid zero pose. Do you get the same with the M4 General poses included with Carrara?
Image Attachments
 Signature
Everything about Carrara: http://www.carraracafe.com/
Profile
Posted: 04 September 2012 07:48 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2005-03-08
I’ve tried importing a duf from DS with no luck, I’ve got it fitted to M4 with no luck I’ve imported a poser file with no luck..
Nothing seems to work with this guy in Carrara. I’ve pointed stuff with no results either.
But I’ll hang onto it in the hope that one day the machine will work rolleyes
Works fine in Poser and DS
Image Attachments
 Signature
“I am,... Therefore I think”
Profile
Posted: 05 September 2012 09:54 AM   [ Ignore ]   [ # 3 ]
Active Member
RankRank
Joined  2012-04-01
The hands and feet issue I think there are 2 solutions for, over in the common thread in either one of both threads named cyber m4.
Post 2 has a file that may or may not help:
http://www.daz3d.com/forums/viewthread/6113/P30
Post 4 has another tip:
http://www.sharecg.com/v/60772/related/11/Poser/Genesis-Hand-and-Foot-Fix-Pose
Dzfire says never use the zero pose.
One more untested trick, export from ds4 with:
http://www.daz3d.com/shop/poser-format-exporter-pfe
Final trick is to convert him to genesis with this instruction far down the thread:
http://www.daz3d.com/forums/viewthread/6753/P105
 Signature
Profile
Posted: 05 September 2012 05:46 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2005-03-08
after trying all the tips..
none worked except for the last one converting him to Genesis did the trick.. although not perfect it at least can be used.
thanks for the links
Image Attachments
 Signature
Profile
Posted: 10 September 2012 09:12 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2011-05-15
I’m confused. Mine moves fine in Carrara.
 Signature
Profile
Posted: 10 September 2012 10:06 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2005-03-08
mine doesn’t work in either Carrara 8.1pro nor 8.5B
weird! rolleyes
 Signature
Profile
Posted: 11 September 2012 10:08 AM   [ Ignore ]   [ # 7 ]
Active Member
RankRank
Joined  2012-04-01
Mine works in Carrara 8.1 Pro, I just load him up from
Browser/Content/Figures/DZFire
Only issue is the broken pistons seen in the second post, when I use the General Poses on him.
 Signature
Profile
Posted: 11 September 2012 11:38 AM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2011-05-15
I use 7 Pro. Not sure if that’s making a difference. (Can’t imagine why it would)
 Signature
Profile
