Digital Art Zone
4 of 5
4
Scripted multipass render to add outlines?
Posted: 20 November 2012 04:28 AM   [ Ignore ]   [ # 46 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
I think there was something about that in the example scripts Rob made: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start (Render to backdrop and/or to Viewport, at the bottom of the linked page). *Sigh* too many fingers in too many pies, I can’t think straight.
Profile
Posted: 20 November 2012 06:16 AM   [ Ignore ]   [ # 47 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
I got a backdrop specified in the camera to work, so I’m going with that for now. But I’ll look at Rob’s examples again—I did read through them a couple of weeks ago, but I understand more about scripting now than I did then….
Profile
Posted: 27 January 2013 11:51 PM   [ Ignore ]   [ # 48 ]
Member
Rank
Joined  2004-10-23
Curious did you ever finish this little project?
Profile
Posted: 29 January 2013 06:08 AM   [ Ignore ]   [ # 49 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Tugpsx - 27 January 2013 11:51 PM
Still working on it. The render works, but there are still too many manual steps to set it up. If you’d like to take a look, pm me.
Profile
Posted: 01 March 2013 06:19 PM   [ Ignore ]   [ # 50 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
When I use the “Save render settings” utility with my Scripted 3Delight settings, it doesn’t capture the render engine information. The file that is created has this info:
"scene" {
"extra" [
"type" "studio_render_settings",
"render_options" {
"aspect_ratio" [ 1013 ],
"startTime" 0,
"endTime" 1,
"renderMovToId" "ImageSeries",
"renderViewport" false,
"isAspectConstrained" true,
"imageSize" [ 500650 ],
"renderType" "Software",
"renderStyle" "Normal",
"rayTraceDepth" 1,
"openGLPasses" 1,
"useGLSL" false,
"isCurrentFrameRender" true,
"useMotionBlur" false,
"motionBlurPct" 100,
"motionBlurSamples" 2,
"xPixelSamples" 4,
"yPixelSamples" 4,
"shadowSamples" 10,
"shadingRate" 2,
"doubleSided" true,
"gain" 1,
"gamma" 1,
"pixelFilter" "Sinc",
"xFilterWidth" 6,
"yFilterWidth" 6
I think I need to change “renderType” to something other than “Software,” but what? Then I’ll also need to select the appropriate script, so I’ll need to figure out what that option is called. There’s no context help for either of these options. Does anyone know how to refer to them in a render preset script?
Profile
Posted: 01 March 2013 11:39 PM   [ Ignore ]   [ # 51 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
I found an old script someone shared with me two years ago, and was able to get the setting renderType to scripted renderer to work. However, I’m still having trouble setting the render script. The log doesn’t show any errors, but if I try to include the variable that should have the path to the script in a messagebox, there’s nothing there.
This sets the path to my render script:
var sRENDER_SCRIPT "support/DAZ/ScriptedRenderer/Outline Compositor/OutlineCompositorRenderScript.dsa"
The list of available scripts works after this is run, but I still can’t figure out how to set it….
Profile
Posted: 04 March 2013 08:50 PM   [ Ignore ]   [ # 52 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Does anyone know how I can determine the name of a widget from strings files or anything like that? I need to know how to refer to the script selector widget.
Profile
Posted: 05 March 2013 08:29 AM   [ Ignore ]   [ # 53 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
What do you mean by widget?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 05 March 2013 09:37 AM   [ Ignore ]   [ # 54 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
In scripting terms, I mean property. I have a variable set to the path to the script I want to use, but I don’t know the name of the property to set to that variable.
Profile
Posted: 05 March 2013 02:20 PM   [ Ignore ]   [ # 55 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
A DzProperty derivative has a getLabel() function and a name member - both strings.
 Signature
Profile
Posted: 05 March 2013 03:04 PM   [ Ignore ]   [ # 56 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Ok, I’ll see if I can iterate through the children of the parent property and find it that way—thanks for the reminder.
Profile
Posted: 05 March 2013 04:35 PM   [ Ignore ]   [ # 57 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
DzProperties don’t have children, so I’m wondering if we are talking about different things.
 Signature
Profile
Posted: 05 March 2013 08:28 PM   [ Ignore ]   [ # 58 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Probably not. I have a terrible time knowing what to call things in this scripting language.
I have set these variables:
var oRENDER_MANAGER App.getRenderMgr();
var
oRENDERER oRENDER_MANAGER.findRenderer("DzScriptedRenderer");
var
and then I want to use them here:
oRENDERER.setRenderScriptsRENDER_SCRIPT );
but it doesn’t work—the value of the script referenced in the Render Settings panel doesn’t change. I suspect the name of the thingy I’m trying to set has changed. ( Where “thingy” here refers to “oRENDERER.setRenderScript()”.)
Profile
Posted: 06 March 2013 10:14 AM   [ Ignore ]   [ # 59 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
No error? I’m not sure what you need, but you can use Rob’s trick to look for the functions in DzRenderer in DS4:
for ( var o in oRENDERER ) {
print ( o );
 Signature
Profile
Posted: 06 March 2013 10:37 AM   [ Ignore ]   [ # 60 ]
Member
Rank
Joined  2010-03-13
zigraphix - 05 March 2013 08:28 PM
var
var
Despite the UI of the render options not changing, it seems “internally” it is working. Via the following script I can invoke the “Point-based occlusion” render without having it selected beforehand:
var oRenderMgr App.getRenderMgr();
var
oRenderer oRenderMgr.findRenderer("DzScriptedRenderer");
oRenderMgr.setActiveRendereroRenderer );
oRenderer.setRenderScript"support/DAZ/ScriptedRenderer/Point-Based Occlusion/PointBasedOcclusionRenderScript.dsa" );
oRenderMgr.doRender();
Profile
4 of 5
4
