Digital Art Zone
Best way to save rigging / skeleton for futre use?
Posted: 01 September 2012 05:58 PM   [ Ignore ]
Member
Rank
Joined  2006-05-09
I just created a fairly complex rig /  skeleton for a trex model. I’d like to keep the rig for future use. what format or procedure is best to save it for reuse?
Thank you!
Profile
Posted: 01 September 2012 06:49 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
You mean a T-rex, as in dinosaur? Is it attached to the model? Have you weight painted it? More info. please.
Profile
Posted: 01 September 2012 07:48 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2006-05-09
Yes T-rex - the dinosaur. I saved the Carrara scene before I attached it to the skeleton.
Profile
Posted: 01 September 2012 08:25 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
You could try and drag it to the object browser. Personally, I would attach it to the model, weight paint it/adjust influences, and group it. Make sure the rig is lined up with the mesh before you start painting the influences, because if you detach the mesh, the weight painting will be lost. Once you have the bone influences how you like them, select the model and the hip bone (if it’s the top bone in hierarchy) and group them. Once that is done, drag the group to your Object Browser and drop it on whatever directory you like. The rig and mesh will be saved as well as influences, etc. If you want the ability to use NLA clips, then use Animation Group under the Animation menu.
Profile
Posted: 01 September 2012 08:29 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2006-05-09
Thank you for the quick and detailed reply.
Profile
