Digital Art Zone
Point Light help in scene
Posted: 01 September 2012 12:12 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2011-02-21
Hello!
I’m doing a night scene and have the lighting for that taken care of.  However I have 6 candles in the scene that I would like to give off light.  I think I’d be using point light with this and would change the colour to give off a warm glow.  However I seem to be screwing something up as when I put it around the flames on the candles it makes the flames black.  I’m guessing putting the light on the flames doesn’t work any idea of the best way to make my candles glow?
EDIT:  I found this on the old forums: http://forumarchive.daz3d.com/viewtopic.php?t=39007  but the links no longer work.
Profile
Posted: 01 September 2012 02:54 PM   [ Ignore ]   [ # 1 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
If you put the light inside the mesh you will get the Black thing as you noticed. You will get a much better effect with a cluster of lights around your light source. You can then use lower settings on the lights that do not matter and still get a great render. This is easier to do than it sounds, use a blank scene with the candle object to set up the lights then delete all but the lights after you group them to a null. Save the set as a Scene file, then just merge as many sets as you need and place them into your working scene.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 01 September 2012 03:04 PM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
What a lot of people do is set the Ambient colour to white and Ambient strength to 100% for the flame material, then position the light just above the flames. If the flames are a separate prop or body part you can also turn off their cast Shadows setting, set the ambient as before, and put the light in the middle of the flame. Note that regular point lights taper off very quickly, especially with the default gamma setting, for candles I usually use a Linear Point Light and adjust the start and end distances to fill the area I’m interested in.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 01 September 2012 06:40 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2011-02-21
Thank you both!  I’ll give both of these a try and will share how it comes out. *G*
Profile
Posted: 03 September 2012 05:52 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2011-02-21
Another problem but running in the same lines.  I have the lights set up the same on all six candles but only three candles are acknowledging the lights.  The other three on the other side of the image act like there’s nothing there.
Profile
Posted: 04 September 2012 10:37 AM   [ Ignore ]   [ # 5 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
DS can only Preview 8 lights in the Viewport. They should still be in the rendered image. Do a spot render and test it.
 Signature
Profile
Posted: 04 September 2012 11:57 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2011-02-21
That’s how I discovered that the lights weren’t showing.  I had everything the way it was suppose to be and started rendering and the lights didn’t show up on the one side.
Profile
Posted: 04 September 2012 12:15 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Are you certain you’re using software rendering?  What are your advanced render settings?
 Signature
My Tutorials and Freebies Index
Profile
Posted: 04 September 2012 01:32 PM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2011-02-21
I’m using software rendering and I keep my advanced render settings on default figuring since I don’t really know anything about that at the moment that it would be best if I only adjust the size
Profile
Posted: 30 December 2012 11:32 AM   [ Ignore ]   [ # 9 ]
Member
Avatar
Rank
Joined  2011-02-21
I’m so far behind on doing this *head desk*  But I wanted to show you guys how the picture came out that you helped me with the lighting with.  I have it posted in my daz account: http://senare.deviantart.com/gallery/32879462#/d5e3kup
Profile
