Wood and gold.
Always Boolean operations.
Always a little ‘difficulty.
I believe that there should be a system to facilitate better definition of the model after Boolean operations.
Bye
Hello to all.
A quick little work.
You have tried to model a pencil?
I do not understand how to transform the polygon to transform it into circular.
Area dedicated to pencil sharpeners.
Bye
If you want to make the sharpened part more round, loop select the edge and copy & paste it. This will tell you how many points you need. Create a circle using the circle from diameter with the desired number of points, then use the ruled surface tool to bridge the 2 curves.
Thank you.
I thought about this…..
Perhaps another way is to change profile with the addition of strings (archi).
.....non so…..
Bye
Here is the “complete” outfit of the Night Warrior. The jacket (with armor plates), shin guards, boots, and gauntlet were all made in Hexagon 2.5, and rigged in Daz Studio 4.0. The claw blades on the gauntlet even extend and retract.
Ciao “W.D.J”.
You can not insert the file directly here on the site?
I do not want to sign up to other sites.
One or two are more than enough for me…...
I’m very sorry.
At the moment I’m keeping myself busy by doing a WIP room, this is one of those projects which can last a while as I fill the room with loads of props.
