Digital Art Zone
8 of 10
8
Hex Gallery
Posted: 19 January 2013 04:32 AM   [ Ignore ]   [ # 106 ]
Member
Rank
Joined  2009-08-21
Ciao.
Mainly (prevalentemente) Boolean operations.
I am not satisfied…..long face (non sono totalmente soddisfatto)
grin
Bye bye
Image Attachments
 Signature
“Il principio della scienza della pittura è il punto, il secondo è la linea, il terzo è la superficie, il quarto è il corpo che si veste di tal superficie”
Leonardo da Vinci
Profile
Posted: 19 January 2013 07:27 AM   [ Ignore ]   [ # 107 ]
Member
Rank
Joined  2006-11-17
Hello m_m_italy,
m_m_italy - 19 January 2013 04:32 AM
Ciao.
Try using bend for main parts.
Simple example.
1: Create curves for shape.
2: Ruled surface. Add edge_loops as needed.
Add 2 curves for 2 planer bends.
3: Bend in 2 planes
(2 pieces welded and bridged)
Image Attachments
Profile
Posted: 19 January 2013 10:25 AM   [ Ignore ]   [ # 108 ]
Member
Rank
Joined  2009-08-21
Ciao Steve.
Difficult for me to explain.
I want to especially thank.
The method that you used is masterful.
Do I have the time to understand.
Again thank you very much.
Bye
 Signature
Leonardo da Vinci
Profile
Posted: 19 January 2013 10:55 AM   [ Ignore ]   [ # 109 ]
Member
Avatar
Rank
Joined  0
Here’s a oil production platform I’m making.
Together with a lifeboat.——(the Sampan is from DAZ):cheese:
At the moment it looks to new and unused, and it does still miss some bits and pieces.
And the shading in Carrara still needs a lot of work.
This is a testrender I did in Carrrara, mainly to see how it would look. I have tried to make it as low-poly as possible.
At this stage it is 66 601 poly’s.
The crane doesn’t look to convincing either.
Image Attachments
 Signature
My freebies : http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Varsel
Profile
Posted: 19 January 2013 01:02 PM   [ Ignore ]   [ # 110 ]
Power Member
RankRankRank
Joined  2004-07-01
Varsel - 19 January 2013 10:55 AM
good start - keep it up
Profile
Posted: 21 January 2013 02:06 AM   [ Ignore ]   [ # 111 ]
Member
Rank
Joined  2009-08-21
Ciao a tutti.
ANELLO:
With reference to the system indicated by Steve.
Is excellent.
But:
Do not think it would be nice and useful to have a system to distribute good points after Boolean operations?
For example, to obtain the curves after Boolean operations and then have the points equidistant.
Or, without altering the shape of the curve, have a different number of points, always equidistant.
Bye
grin
Image Attachments
 Signature
Leonardo da Vinci
Profile
Posted: 21 January 2013 02:10 AM   [ Ignore ]   [ # 112 ]
Member
Rank
Joined  2009-08-21
The model is well done.
Bravo.
Render, in my opinion could be improved.
I would change the sea.
Bye bye
 Signature
Leonardo da Vinci
Profile
Posted: 21 January 2013 11:50 AM   [ Ignore ]   [ # 113 ]
Member
Rank
Joined  2009-08-21
ANELLO:
finito.
Bye
grin
Image Attachments
 Signature
Leonardo da Vinci
Profile
Posted: 21 January 2013 11:55 AM   [ Ignore ]   [ # 114 ]
Member
Avatar
Rank
Joined  0
The modeling is done. 165 615 poly’s
A render done in Carrara. It isn’t UV-mapped (except the signs and net on the helideck)
So there are some work to be done with procedural shaders…
It looks a bit empty on the top deck, but in the final picture there will be some containers and other props.
It is also made in Poser scale, so I will also populate it with some figures.
As you can see in the background, I have also created an environment to put it in.
Would properly not be certified by Lloyds or Veritas or Greenpeace.
Image Attachments
 Signature
Profile
Posted: 22 January 2013 08:38 AM   [ Ignore ]   [ # 115 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Very well done - seriously complex modeling - all in one Hexagon file?
Profile
Posted: 22 January 2013 09:44 AM   [ Ignore ]   [ # 116 ]
Member
Avatar
Rank
Joined  2005-09-15
Beautiful design and, modeling.
Image Attachments
 Signature
Cheers, Fanners.raspberry
Profile
Posted: 22 January 2013 10:37 AM   [ Ignore ]   [ # 117 ]
Member
Avatar
Rank
Joined  0
Roygee - 22 January 2013 08:38 AM
Thank’s.
The crane, lifeboat and the lifeboat-davit was modeled separately, and imported back in to the master file.
The trick I used was to combine things in groups, and then hide groups when I should create something new.
And m_m_italy
It’s a beautiful bracelet. You are a great artist.
 Signature
Profile
Posted: 22 January 2013 10:48 AM   [ Ignore ]   [ # 118 ]
Member
Avatar
Rank
Joined  2008-11-04
m_m_italy - 21 January 2013 11:50 AM
ANELLO:
finito.
Bye
grin
Another great render! You do really good work! smile
 Signature
“We probably wouldn’t worry about what people think of us if we could know how seldom they do.”
Mark Twain
Profile
Posted: 22 January 2013 11:43 AM   [ Ignore ]   [ # 119 ]
Member
Rank
Joined  2009-08-21
Thank you friends.
You are very generous to me.
Unfortunately I can not reciprocate because I can not speak English.
My interventions are unclear because I stutter.
Aspect to observe your good works.
P.S.
Now the ring is actually completed.
Bye bye
Image Attachments
 Signature
Leonardo da Vinci
Profile
Posted: 22 January 2013 12:13 PM   [ Ignore ]   [ # 120 ]
Member
Avatar
Rank
Joined  2005-09-15
LOL  LOL  LOL  I thought your ring was a bracelet.  cheese
 Signature
Profile
8 of 10
8
