Digital Art Zone
9 of 14
9
RAMWolff’s Freebies Pages *Morphs for Genesis NOW LIVE!  See first post!*
Posted: 30 November 2012 04:41 PM   [ Ignore ]   [ # 121 ]
New Member
Avatar
Joined  2003-12-27
The auto fit clothing from another model to Genesis you will need to create a morph that has the exact size and shape as the original figure. Load it as a morph target with morph loader pro. After doing so go to the “Parameter Settings” and change the type from “Modifier/Shape” to “Modifier/Clone” now the new shape will show up in the auto fit menu, don´t forget to save it, use “Morph Asset”.
For the Horse 2 it was not that difficult as Horse 2 is based on the Millenium Horse.
It will be very difficult to clone Apollo to Genesis so it´s probably easier to fit the clothes manually in a modelling app like blender or Hexagon and then import and save them to Genesis.
Image Attachments
 Signature
My freebies: http://sites.google.com/site/crblackthorne/
Profile
Posted: 30 November 2012 05:16 PM   [ Ignore ]   [ # 122 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
I’m loving your head enhancement morphs!
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 30 November 2012 08:53 PM   [ Ignore ]   [ # 123 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Thanks much Cauri.  grin  Yea, I figured it was going to be more work than it’s worth.  After pretty much the same advice from Richard H.  I had tried that already and failed to create a shape that was close enough.  Was hoping there was another way around this but I guess not…  Onwards and upwards.
Thanks Wancow.  Glad your enjoying the works!  grin
 Signature
—-Wolff On The Prowl—-
Posts: 28,985 and counting!
        RAMWolffsWorld
Profile
Posted: 03 December 2012 02:17 PM   [ Ignore ]   [ # 124 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Happily shocked.  Decided to convert some of Adzan’s fabulous works over to Genesis since there is a Hiro 3 template…. OMG.. the boots are nearly perfect.
Off to lunch and errands…
C’ya
Image Attachments
 Signature
        RAMWolffsWorld
Profile
Posted: 03 December 2012 07:11 PM   [ Ignore ]   [ # 125 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Home from errands and back to conversions…. This was and now is BACK to being a favorite of mine… Osculus.  Fully converted, including the boots (see post above this one) and applied the Child morph to Genesis and it scales extremely well.  grin
Image Attachments
 Signature
        RAMWolffsWorld
Profile
Posted: 05 December 2012 06:04 PM   [ Ignore ]   [ # 126 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Played around with some textures I made a while back and came up with this striking combo for Adzan’s outfit I converted over to Genesis!
grin
Image Attachments
 Signature
        RAMWolffsWorld
Profile
Posted: 05 December 2012 09:10 PM   [ Ignore ]   [ # 127 ]
Active Member
Avatar
RankRank
Joined  2009-01-09
RAMWolff - 05 December 2012 06:04 PM
grin
Oooo ... Is this something you can post somewhere? Is it actually textures, or shaders?
 Signature
VWrangler at deviantArt (NSFW for some images; login required to view those)
Profile
Posted: 05 December 2012 10:16 PM   [ Ignore ]   [ # 128 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
I might do that eventually.  I was thinking about a small texture shader pack but that’s another one for the list.  Glad you like it!  grin
 Signature
        RAMWolffsWorld
Profile
Posted: 06 December 2012 10:45 AM   [ Ignore ]   [ # 129 ]
New Member
Joined  2011-11-17
RAMWolff - 11 November 2012 11:36 PM
Getting to know the Spotlight tool in ZBrush is fun and frustrating but so far it’s the easiest polypainting tool I’ve found.  Here is the beginning steps to set up Genesis followed by a link to learn more about Spotlight:
Spotlight is connected to Lightbox but you don’t have to learn how to use Lightbox if you don’t want.
1) Load up Genesis via GoZ or obj import.  Then Tools>Polygroups>Auto Groups with UV to set up the UV’s in ZBrush for Genesis…
Next step is time consuming but important and will make your experience much more enjoyable since you will save this out as a reusable file.
2) Set up Groups:  To set up groups:
Using your Ctrl + Shift and CLICK ... One click on the Head will hide everything else, right?  If you’ve not tried this, try it.  To get everything back just do the same key strokes and CLICK in an empty area of the workspace and it will all come back.
One important thing to remember is to make sure you have a full view turned on.  To do this is in your Tools palette scroll down till you come to Display Properties, click the title and it will open up.  Click the “Double” button and that will make sure that backfaces are turned on so when your setting up your groups you don’t miss some of the vertices’s.
OK… So lets set up the Inner mouth group first.  Ctrl + Shift and CLICK the head, it will then be the only thing in the scene, Ctrl + Shift and CLICK again and it will disappear and the rest of the body will be visible.  Ctrl + Shift and CLICK the back of the head, each ear and the neck to make them invisible, do this for all the rest… yea, even those damned finger and toe nails.  (I told you this first part is time consuming).  Once you have all the parts invisible you will have a choice.  The inner mouth and eye parts will be left.  You can either group all of these as one group making it easier to turn off or you can Ctrl + Shift keys + Drag Select with the cursor to select the Eye parts and they will disappear too….. Now to group the Mouth parts.
Tools>Polygroups>Group Visible.  You will see the color of the inner mouth change to a unified color.
Ctrl + Shift and CLICK in a blank area to bring it all back.  Now get those nails (toe and finger) grouped the same way.  Hide all the other parts using the Ctrl + Shift and CLICK method EXCEPT leave all the nails showing.  Then Tools>Polygroups>Group Visible.  Do the same for the Eye parts.  Then the Limbs.  Then the Torso & Ears and then you have the Head left over.
3) Then Tools>Geometry>Divide up 3 times, 4 if your system is powerful enough.
4) Then go to Tools>Geometry HD and divide up 3 times.
5) Then Tools>Polypaint and make sure that the Colorize button is on.
6) Then Up on the main bar make sure your MRGB is on and the ZAdd is off or turned down to at least 3 or 5 (I use this to add detail so keeping it low like that will pick up bits of the highs and lows in the texture map)
7) Next lets put on a primer coat.  First of all you want a nice neutral shader.  Shaders palette flyout… choose the SkinShader4.  Should be right there at the top.  Next up to the Color drop down palette and choose Fill Object.  NOTE: If you choose Fill Layer you will fill the entire work space with that color.  Not what we are after here.
8) Now your going to save this out as a file….. Save As, browse to where you want to keep it, name it and save it out as a ZTL file.  Mine is called GenesisPolypaintSetup.ZTL
9) Now making sure you change your MRGB to RGB up top.  Go to your Materials and Import your desired texture (might want to practice with one that comes with ZBrush to make sure your getting before jumping in full board.)  Double click the texture and that will load into the palette memory.  Now go up to the Texture drop down palette and there is a set of 4 buttons.  Hover over them:
Button 1: Transparent Texture
Button 2: Antialiased Texture
Button 3: Turn on Spotlight
Button 4: Add to Spotlight
You want to concentrate on Buttons 3 & 4.  You will need to click on Button 4, Add to Spotlight.  This will load the texture and turn on Spotlight.  If it doesn’t turn on then click Button 3 and will turn it on.
NOTE:  To turn Spotlight on and off learn Shift Z.  To turn off the widget learn Z.  Hiding the widget also activates the brush to paint.  You will really need to learn how to use all the buttons on the widget.  There are allot of them but it’s good to know what your doing.
10) Below is a link to Pixologic with a nice full list of vids to get you more familiar with Spotlight.  SO please spend an hour watching the video’s in the order of which you see them listed so you get a good grasp of what each button does.  Make sure you bookmark this link so you can refer back to the page to vids you really need to brush up on.  I do all the time.
http://www.pixologic.com/zclassroom/homeroom/lesson/spotlight/
I’m still learning myself but I’m moving ahead with each day and time spent practicing.  There is NO easy way to learn polypainting but I’ve found this is the easiest by far so far.
Have fun!
Richard
Thanks for this link from the other thread. A very thorough tut indeed! Really appreciate it.
I’m beginning to get the gist of custom clothing pipeline between Daz and Zbrush. Maybe I’m too ambitious about morphing a Genesis with its original textures on, or retexturing an existing map with Zbrush on the mesh itself, eyes/face/body on at the same time for reference.
After much reading between Daz and Zbrush forums, I’m still trying to understand, with Transfer Utility and Smooth Modifier/Collision etc which will make most clothing types fit to Genesis, and ability to GoZ or Modo, why is there a need to go through rigging/ bone/ weightmap? Am I missing something obvious again?
Thanks again for the pointers.
Profile
Posted: 19 December 2012 01:06 PM   [ Ignore ]   [ # 130 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Just a note to all those waiting still for me to finish up Bruno.  It’s going to be a while longer.  My right shoulder froze up.  I’ve been off work going on 2 weeks.  Been seen by my doctor and seeing an acupuncturist which is doing wonders for the pain and getting things moving again.  So long stints on the computer right now are a no no and with me still learning texturing in ZBrush… well at this point I’d count on a Spring release!  lmao I’m back to work next week so we shall see how I hold up.  I do apologize for not tending to this thread but thought you all deserved an explanation as to what happened.  Not shelved at all but delayed.  Happy Holidays to one and all.
 Signature
        RAMWolffsWorld
Profile
Posted: 19 December 2012 01:36 PM   [ Ignore ]   [ # 131 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Thanks for the update, you take it easy and get better.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 19 December 2012 02:35 PM   [ Ignore ]   [ # 132 ]
Member
Avatar
Rank
Joined  2005-11-24
Thanks for letting us know. Take care of yourself.
 Signature
Profile
Posted: 19 December 2012 02:58 PM   [ Ignore ]   [ # 133 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
You are supposed to have someone else holding the camera when you are trying to get those detailed shots of the shoulder…besides wouldn’t it have just been easier to get a 3d scan done?
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 19 December 2012 03:05 PM   [ Ignore ]   [ # 134 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Thanks folks.
*one handed tickle torture for mjc* raspberry
 Signature
        RAMWolffsWorld
Profile
Posted: 25 March 2013 01:45 PM   [ Ignore ]   [ # 135 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Coming Soon-ish…
Simple Suit set…..
Simple Suit (with many zones)
Flat Boots (5 morphs: SimpleSuit fit, Rounded Top 1 & 2 and SupesTop 1 & 2) (the 2nd of each are proper fits for the Simple Suit)
Heeled Boots
Short Gloves (with cuff)
Simple Gloves
Cuffed Gloves
Long Gloves (with cuff)
Mask (with many zones)
Spent the last couple of months really getting to know ZBrush.  Had some great help from JoeQuick, Mec4D, SickleYield and Slosh and LOTS of YouTube vids and tutorials at ZCentral.
At first I was happy with using Joe’s freebie suit that he released to the wild.  But in order for Me to say “this is all my work” I needed to learn how to make my own full body suit.  SO I did learn.  ZSphere’s to the rescue and LOTS of patience with the learning process.
As I started learning how to add zones into the suit I realized for a more robust suit set I’d need to figure out how to make boots and gloves.  Gloves are NOT easy as I found out but got it eventually.  Shoes are my new passion. These boots are my first try so they are NOT perfect but they are good.  Not great, but good!
I’m not totally done with the morphs but wanted to post some screen shots!
Image Attachments
SimpleSuit-SurfacesList.jpgSimpleSuit-Mask-SurfaceZones.jpgSimpleSuit-Gloves01-FlatBoots-Mask.jpgSimpleSuitGloves-Zones.jpgSimpleSuit-HeeledBoots-Zones.jpg
 Signature
        RAMWolffsWorld
Profile
9 of 14
9
