amy_aimei - 04 September 2012 08:31 PM
Installing both 4.0.x and 4.5 on the same PC is tricky. I messed up my installation already. I’ve to re-install again. I think using virtual machine may be safer.
I wondered if I just changed the line 2 in the file from
“file_version” : “0.6.0.0”,
to
“file_version” : “0.5.0.0”,
will solve the problem of compatibility. Could someone try?
Patience55 and Takeo, thank you for the nice renders! Is it hard to fit clothes on my morph?
The file version was not the only problem. Didn’t want to say it but there was a problem in the path declared in the file which was different from where you placed it. There is also something else but I didn’t want to spend time finding what
Fitting the cloth on your morph is like fitting anything on Genesis. If the Autofit or CCT does the job right there is no issue
